(2016-03-30, 08:54)DanTheMan827 Wrote: [ -> ] (2016-03-30, 08:02)DobyxRC Wrote: [ -> ]Sorry if this has been talked about already but here's my situation. I have Kodi on ATV4 and all is well, but I have not update the ATV4 as I know I will loose the app. I want to know if I can still update the ATV4 then side load the app again even if I don't have any of the original .ipa file?
Any help would be much appreciated
Yes you can update and re-install Kodi again
As long as you use the same ID to re-create the IPA file you won't even lose any data.
If you don't remember what that ID is you can connect the Apple TV to Xcode and open up the devices window, that will list the installed apps and their identifiers
Thanks Dan, Can a person install Kodi with a brand new ATV4 with the latest IOS on it or is that still in the works?
(2016-04-02, 18:05)DobyxRC Wrote: [ -> ] (2016-03-30, 08:54)DanTheMan827 Wrote: [ -> ] (2016-03-30, 08:02)DobyxRC Wrote: [ -> ]Sorry if this has been talked about already but here's my situation. I have Kodi on ATV4 and all is well, but I have not update the ATV4 as I know I will loose the app. I want to know if I can still update the ATV4 then side load the app again even if I don't have any of the original .ipa file?
Yep, the latest versions of both iOS and tvOS are compatible
Where can I get the latest Kodi .deb files for installing via Xcode on tvos?
Thanks very much smeagol152!
trying to install Kodi for apple tv 4 but am getting a strange error in xcode saying that i need to register device .....but i already have set up a profile previoiusly when i put Kodi on my ipad....any ideas....one other thing i am using the apple adapter from usb-c to usb-a would that have anything to do with it?
Yes, I also tried various adapters and they didn't work. Had to use the usb A - usb C
At first my provisioning profiles showed in the App Signer app as per the instructions then began showing as only " * (NVW93XXXX)" rather that the com.Name.
Now the latest one does not show in the list at all.
I use a paid Dev account.
Any ideas?
(2016-04-07, 22:44)bovice Wrote: [ -> ]At first my provisioning profiles showed in the App Signer app as per the instructions then began showing as only " * (NVW93XXXX)" rather that the com.Name.
Any ideas?
Xcode will use a * profile if there is nothing special needed, this is the case for Kodi unless you enable the app group needed for the top shelf on Apple TV
Could you post the log for iOS App Signer? (It's in the View menu)
2016-04-07 18:47:03 Found 12 Provisioning Profiles
2016-04-07 18:47:03 Added profile *, expires (2017-04-07, 12:11:48 PM)
2016-04-07 18:47:03 Added profile *, expires (2017-04-01, 2:02:13 PM)
2016-04-07 18:47:03 Added profile *, expires (2017-03-31, 1:59:05 PM)
2016-04-07 18:47:03 Added profile com.xxx.KODIMARCH10, expires (2016-06-11, 6:54:23 PM)
2016-04-07 18:47:03 Added profile com.xxx.Kodi0319, expires (2017-03-31, 2:01:29 PM)
2016-04-07 18:47:03 Added profile com.xxx.Kodi0319, expires (2017-03-31, 1:59:41 PM)
2016-04-07 18:47:03 Added profile com.xxx.KodiB, expires (2016-06-11, 8:49:42 PM)
2016-04-07 18:47:03 Added profile com.xxx.KodiBn, expires (2016-06-11, 7:41:53 PM)
2016-04-07 18:47:03 Added profile com.xxx.KodiMarch, expires (2016-06-11, 7:32:28 PM)
2016-04-07 18:47:03 Added profile com.xxx.KodiTest, expires (2016-06-11, 7:46:41 PM)
2016-04-07 18:47:03 Added profile com.xxx.jailbreak.livehdj, expires (2016-07-06, 1:31:23 PM)
2016-04-07 18:47:03 Added profile com.swiftallmighty.KodiAppleTv, expires (2016-04-19, 7:15:44 PM)
2016-04-07 18:47:03 Found 2 Codesigning Certificates
2016-04-07 18:47:03 Added signing certificate "iPhone Developer: X Xhotmail.com (993RFRKL4B)"
2016-04-07 18:47:03 Added signing certificate "iPhone Developer: X X (SPJD9TQWLZ)"
2016-04-07 18:47:03 Loaded Codesigning Certificate from Defaults: iPhone Developer: X X (SPJD9TQWLZ)
2016-04-07 18:47:03 Ready
When i switched over to my Free account in xcode the porfile showed up for it but when i use the paid account no new profile shows up in the list
2016-04-07 18:47:03 Added profile com.nugz.jailbreak.livehdj, expires (2016-07-06, 1:31:23 PM)
Hi All,
I have limited tech experience other then following step by step instructions.
I am having problem loading Kodi to my Apple TV 4 running tvOS 9.2. I am connected to my MacBook running El Capitan via a USBC to USBC cable.
I have followed the step by step instructions here,
http://www.thestreamingadvisor.com/2015/...-apple-tv/
Everything seemed to be going to plan up to the point of loading the .ipa file to the AppleTV where Xcode returned the error
'app installation failed no code signature found'
I would appreciate any guidance how I can resolve this issue.
I side loaded kodi with no problems on 9.3. However, I think with the latest ios9 update, kodi never opens up for me anymore. The screen goes black like the app is going to start and then goes back to the home screen. Does anybody else have this problem? Do I need to re side load? Will I lose all my settings if I do this? Thanks for any help.
Hi
Can anyone post the latest kodi test build with the .ipa extension not deb?
(2016-04-12, 00:49)Illest Wrote: [ -> ]Hi
What benefit would there be?
You can't install an IPA without signing it and iOS App Signer supports the deb directly.
If you're jailbroken you would just use the deb anyways.
