2018-11-06, 15:23
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
2018-11-11, 11:51
Hi Guys,
I have a small problem that I get the error message: App installation failed. This application does not support this kind of device.
I have a Apple TV. I selected in Xcode also tvOS. I go step by step the instructions for Xcode and iOS App Signer. Tried the unstable release 18.0 Beta 5 also stable release 17.6.
But have the same error message.
Thank you in advance for your support.
2018-11-11, 12:04
There is no Kodi 18 for tvOS at the moment.
Here you find the latest tvOS builds based on Kodi Krypton:
http://mirrors.kodi.tv/test-builds/darwin/tvos/
The tvOS port needs maintainers:
https://forum.kodi.tv/showthread.php?tid=326914
If you see yourself in a position to help, you would make some people happy here.
Regards
Regards
2018-11-20, 14:33
I just did this again yesterday after about a year. I had to try and remember the process becasue I had a hell of a time about a year ago trying to get it onto my iPad. So here are some of the errors I figured out hopefully it helps someone else. The ipa file you create with the Appsigner has to have the same name as the app you create in XCode. When you open XCode before you start doing the steps make sure your iPad/iPhone is connected. Then in the upper left corner click where it says iPhone XR etc. Then at the top select your device. It should at some point suggest you go to settings, general, device management and authorize or trust your dev ID on the device. Then follow the rest of the steps on the first page and you should be golden.
2018-12-08, 20:30
Has anyone been successful in getting the iOS signer to work with Xcode 10.1 and Mojave?
I am assuming the issue is Xcode 10.1 based as it had worked previously. The error is the unable to fix error.
2018-12-10, 15:03
There is a guide to update Kodi on iOS on removed.
2018-12-10, 18:17
Please don't post promotional links to such sites, especially ones that peddle things like VPNs which Kodi does not need.
2019-01-03, 16:22
(2015-11-01, 21:56)DanTheMan827 Wrote: [ -> ]your signing certificate and the profile.
Hi Dantheman - I followed these instructions as closely as possible and I still can't get codesigning and the provisional profile work correctly and so I am unable to make the IPA -- when I do make the IPA, I can't
load it onto the appleTV4 device because it returns an provisional profile expired or revoked. I have probably redone this 20 times without success. I need some help if you offer support. Thank you
2019-01-06, 19:12
Hello - So I am a newbie here.
Let me start off by saying I installed Kodi with iOS App Signer just under a year ago and it was perfect. Now - maybe coincidentally - Kodi is no longer working. One solution was to reinstall (no audio signal issue). No big deal. Well now I cannot get anything to work. I am using:
Xcode 10.1
iOS App Signer 1.10
tvOS 12.11 (I think this is where it started)
I also have a paid dev account
I've revoked, removed, cursed at certificates until I am blue in the face and knuckles. So a few things happened also.
When I logged into my dev account (first time in 9 months probably) it prompted me to accept new terms and conditions (could not do anything until I did that).
I have tried logging out through Xcode and back in.
I manually added all certificates.
When I build a project I see the cert reference code 3J######
When I go to iOS App Signer I cannot get it to see the Provisioning Profile cert. Signing certificate is correct.
So either Xcode is not generating it (but not throwing any errors) or App Signer cannot see it or locate it.
I am sure it is probably a stupid, simple fix but HELP - thanks
Xcode 10.1
iOS App Signer 1.10
2019-01-08, 18:19
So going further down this rabbit hole - I do have a Paid dev account so I contacted Apple and they sent the steps copied below. For whatever it is worth in the past I was NOT doing steps 7-9. So that is all done.
Open Xcode I see Signing Certificate iPhone Developer: USER NAME (3J########). This matches what is in the keychain.
Open iOS App Signer - Signing Certificate is correct and matches
Provisioning Profile is still not seeing it. It shows Re-Sign Only, Choose File - and then it shows a old profile that does not match the certificate "tvOS Team Provisioning Profile: *(VK##########)"
So I am guessing the * means it is an old profile/reference that it can no longer find. But how do I get it to point to the new/correct one?
Sign in to Apple Developer.
2. Click on "Certificates, Identifiers & Profiles".
3. Click on “Development" under the “Certificates” section, and click on your distribution certificate.
4. Click Revoke and follow the instructions.
5. Click on the plus sign to add a new certificate.
6. Select “iOS App Development" option, and click Continue.
7. Follow the steps printed in the webpage. That involves opening the Keychain application on your Mac and generate a Certificate Signing Request from there. Click Continue.
8. Upload the .CSR file and click Continue.
9. A certificate is generated for distribution. Download it and double click it to integrate it in your keychain.
2019-01-21, 17:37
(2019-01-08, 18:19)wessidetempest Wrote: [ -> ]So going further down this rabbit hole - I do have a Paid dev account so I contacted Apple and they sent the steps copied below. For whatever it is worth in the past I was NOT doing steps 7-9. So that is all done.Did you succeed in getting Kodi loaded? I am about to embark on the same process as my old version uploaded with Xcode 9 has expired and I haven't used Xcode 10.1 before.
2019-01-21, 23:36
So I figured out my problem(s). So I will try to start list the problem and the solution in order.
Problem
Problem
- December (I think exact date escapes me) there was an update to the tvOS and MAYBE coincidentally the audio was no longer working for Kodi. It was not the volume or anything like that and one solution was to reinstall Kodi. No big deal (or so I thought).
- Preface: I have a paid Apple Dev account. I logged into my account (for a unrelated reason) and there was a notice of terms updates that I had to agree to. My only option was to close/quit everything or agree to the terms. Maybe a coincidence but that is when everything seemed to fall apart as the certificates were no longer valid.
- I used this tutorial over a year ago and it worked great then. https://www.youtube.com/watch?v=ZqZZ_c2kF4U I wen to follow the same instructions and I was running into all sorts of errors, Provisional, App invalid etc.
Solutions but it took a while to piece it together
- DantheMan has many helpful and useful one of them was the mention of the WWDR certificate being expired. What I discovered is that I had many certificates that were expired in Keychain Access. I deleted all of the expired ones. Downloaded the new WWDR and installed.
- NOW with that being said. Even though I did View>Show Expired Certificates in Keychain it would NOT show me the expired WWDR cert in "login".
- So one thing that kept coming up was to Revoke your certs in your Dev account and create a new one. Which I did. Downloaded and installed it. BUT there was a critical issue that I was either overlooking and/or was not being mentioned. Provisional Profile creation.
- In your Dev account go to Account > Certificates, Identities & Profiles > Provisioning Profiles (left side bottom) > All. This THIS is what I was missing. I had nothing listed in this area and this is what I was missing. Click + > Development > tvOS App Development > Continue > Select App ID > Continue > Select your computer name you are working on > Continue > the device you want to install on (if it is not listed you need to do that through your dev account) > Continue > here you can give the certificate a unique name > Continue. The Provisioning Profile is now created. BAM
- In the list select your new Provisioning Profile and download it.
- Once downloaded double click it to install it. BAM
- NOW go to iOS App Signer and the Provisioning Profile will now show up and it will build and work as it should.
2019-01-21, 23:37
Yes - look below. Basically I was missing the Provisioning Profile in the App Developer Account. Xcode was not generating it. I cannot believe how many steps I worked around to try and get this to work.. Using Time Machine to revert to old system. UGH. Good luck.
2019-01-22, 00:13
(2019-01-21, 23:37)wessidetempest Wrote: [ -> ]Yes - look below. Basically I was missing the Provisioning Profile in the App Developer Account. Xcode was not generating it. I cannot believe how many steps I worked around to try and get this to work.. Using Time Machine to revert to old system. UGH. Good luck.Thanks- I've created a new Provisioning Profile as per your instructions and will give it a try tonight! If it works, you are my new superhero!
2019-01-22, 01:00
(2019-01-21, 23:37)wessidetempest Wrote: [ -> ]Yes - look below. Basically I was missing the Provisioning Profile in the App Developer Account. Xcode was not generating it. I cannot believe how many steps I worked around to try and get this to work.. Using Time Machine to revert to old system. UGH. Good luck.Worked perfectly for me using Xcode 10.1. Thanks again! I have this page bookmarked for this time next year!
