2024-09-26, 05:24
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
2024-10-12, 18:58
Also having the same issue with Xcode 16. Anybody got a solution?
2024-10-15, 08:50
(2024-10-12, 18:58)rudyamaro Wrote: [ -> ]Also having the same issue with Xcode 16. Anybody got a solution?
build the app signer from source. Here are more detailed instructions: https://github.com/DanTheMan827/ios-app-...2391792040
2025-01-03, 07:13
I found a site that referred KODI for the Amazon Fire Stick. So far I haven't found any instructions on how to install KODI on the Fire Stick, nor does there seem to be any references to the Stick. If it is possible to install KODI on the Fire Stick, can someone please provide me a link to the installation steps? Thank you so much.
2025-01-05, 14:50
Tried to install on an Apple TV 4 /2nd gen., 18.2) on a Mac with 15.2 with newest XCode (from App Store) and iOS App Signer. With a free account, not a developer one.
It fails with error, everytime. It shows up on the Apple TV 4 screen but then gives an error shortly before finishing the installation.
May it be that this possibility of installing Kodi onto an Apple TV 4K is gone?
2025-01-07, 13:22
(2025-01-03, 07:13)MacCoach Wrote: [ -> ]I found a site that referred KODI for the Amazon Fire Stick. So far I haven't found any instructions on how to install KODI on the Fire Stick, nor does there seem to be any references to the Stick. If it is possible to install KODI on the Fire Stick, can someone please provide me a link to the installation steps? Thank you so much.please ask your question in the Android subforum: https://forum.kodi.tv/forumdisplay.php?fid=164
(2025-01-05, 14:50)loadamasta Wrote: [ -> ]Hi,no. it's not gone. Try using the latest available build of App Signer from https://github.com/DanTheMan827/ios-app-...h%3Amaster . Click the latest (topmost) build and download its artifact (in the bottom of the page).
2025-01-08, 17:13
Thank you for the hint. But it did not work. It shows the same error:
"Application is missing the application-identifier entitlement." UserInfo={LegacyErrorString=ApplicationVerificationFailed, FunctionName=-[MIInstallableBundle _validateApplicationIdentifierForNewBundleSigningInfo:error:], SourceFileLine=1129, NSLocalizedDescription=Application is missing the application-identifier entitlement.}}, NSLocalizedDescription=„Kodi“ kann nicht installiert werden, NSLocalizedRecoverySuggestion=Application is missing the application-identifier entitlement., NSLocalizedFailureReason=Versuche es später noch einmal.}}, NSLocalizedDescription=Failed to install the app on the device.}
Any ideas?
Any ideas?
2025-01-10, 20:44
(2025-01-08, 17:13)loadamasta Wrote: [ -> ]Hi,
Any ideas?
were you able to sign it successfully before?
please show what settings you set in the App Signer
2025-01-16, 19:01
(2025-01-07, 13:22)kambala Wrote: [ -> ]no. it's not gone. Try using the latest available build of App Signer from https://github.com/DanTheMan827/ios-app-...h%3Amaster . Click the latest (topmost) build and download its artifact (in the bottom of the page).
Just a note that it works well, but I needed to sign in to GitHub to get the download arrow.
