(2015-11-03, 13:21)badaas Wrote: [ -> ]also noticed in latest confluence yes/no dialog labels missing
i can't reproduce this one.
if i switch to confluence i displays yes/no just fine.
can you test that particular dialog?
please post a screenshot of one where the labels are missing.
In my working Projekt still the same.
yes/no comes with text on first time and afterwards in the same window without text
up to the next reload skin or window change.
(2015-11-03, 15:15)Marc0810 Wrote: [ -> ]In my working Projekt still the same.
can you provide a step-by-step guide on how to reproduce that?
(2015-11-03, 16:21)ronie Wrote: [ -> ] (2015-11-03, 15:15)Marc0810 Wrote: [ -> ]In my working Projekt still the same.
To check skin settings for deactivate library data provider and extended info widgets/contents, I removed all script and programm addons.
In my home afterwards the yes/no dialog comes when i scroll to the mainmenue.
One time with text, second time without up to next reload skin.
On labels with regular color, as $VAR[color], direct in the label or without information expect the defaults.xml.
I´ve Check the Testbuild later.
regards
(2015-11-03, 18:52)Hitcher Wrote: [ -> ]Windows test build here -
http://mirrors.xbmc.org/test-builds/win3...-label.exe
Hey Hitcher..
Same result.. For a quick test i copy two confluence viewcontainer at the end of the Home.xml and placed a content from an missing addon in both.
<variable name="test">
<value condition="Window.IsVisible(home)">plugin://service.library.data.provider?type=recommendedepisodes&reload=$INFO[Window(Home).Property(recommendedepisodes)]</value>
<value></value>
</variable>
<control type="fixedlist" id="501">
<left>-183</left>
<top>0</top>
<width>1343</width>
<height>390</height>
<onleft>501</onleft>
<onright>501</onright>
<onup>2</onup>
<ondown>60</ondown>
<viewtype label="31028">bigwrap</viewtype>
<pagecontrol>60</pagecontrol>
<scrolltime>200</scrolltime>
<focusposition>3</focusposition>
<orientation>horizontal</orientation>
<preloaditems>4</preloaditems>
<itemlayout height="310" width="218">
<control type="image">
<left>2</left>
<top>40</top>
<width>214</width>
<height>310</height>
<aspectratio>stretch</aspectratio>
<bordertexture border="5">button-nofocus.png</bordertexture>
<bordersize>4</bordersize>
<texture background="true">$VAR[PosterThumb]</texture>
</control>
</itemlayout>
<focusedlayout height="310" width="218">
<left>2</left>
<top>40</top>
<width>214</width>
</control>
</focusedlayout>
<content limit="14">$VAR[test]</content>
</control>
<control type="fixedlist" id="3501">
<left>-183</left>
<top>0</top>
<width>1343</width>
<onup>2</onup>
<ondown>60</ondown>
<left>2</left>
<top>40</top>
<width>214</width>
</control>
</itemlayout>
<left>2</left>
<top>40</top>
<width>214</width>
</control>
</focusedlayout>
</control>
In Setting Window on wwitch to confluence all OK, in Home without text.
Regards
@ronie: care to spilt this thread for each issue?
EDIT: Thanks ronie.
(2015-11-04, 17:45)Marc0810 Wrote: [ -> ]For a quick test i copy two confluence viewcontainer at the end of the Home.xml and placed a content from an missing addon in both.
yeah, i can reproduce it that way.
might have something to do with two yes/no dialogs being activated at the same time?
... just guessing.
(2015-11-04, 18:11)ronie Wrote: [ -> ] (2015-11-04, 17:45)Marc0810 Wrote: [ -> ]For a quick test i copy two confluence viewcontainer at the end of the Home.xml and placed a content from an missing addon in both.
... just guessing.
Hmm.. In my skin i have it as contents with visibles on mainmenue focus.
But yes, the error comes as soon as the dialog show more than one times.
The mistake came even because I intentionally has provoked the dialogs
to suppress it with variables and settings.
regards
