New Update 1.0.3:
Add Home menu to player controls window when nothing is playing.
Add possibility to show ClearLogo on widget tile in skin settings.
Add new necessary addons menu in skin settings.
Add text info for each skin settings.
Add Info List 2 (Info list without side poster).
Changes on video OSD.
Replace lyrics font.
Fix lyrics on music visualisation.
Add option to turn plot off in hub widget.
Add debug mode in skin settings.
Add indicator icons for episodes to Big Icon view.
Browse skin icons in panel.
Fix audio icon on dialog info.
Fix codec info overlay colour for light theme.
Love the improvements, thank you!
I have a small request....is it possible to add an option to play the music viz (for example my milkdrop 2 presets) as a background in the main menu?
I love this skin. However, I am getting dependencies not met when attempting to install it. Any ideas?
(2015-11-26, 15:47)Shogun Wrote: [ -> ]Love the improvements, thank you!
I will see that but i'm not sur to do that
(2015-11-27, 07:51)dibson Wrote: [ -> ]I love this skin. However, I am getting dependencies not met when attempting to install it. Any ideas?
Do you use Jarvis ?
Thanks Guilouz!!
I wasn't on Jarvis and updating to Jarvis resolved my dependency issue. I really love this skin. Thanks for the awesome job.
Couple more things:
1. Is there anyway I can reduce the transparency (increase the opaque) of the background images to be more vivid? I am referring to the movie/TV Show background image that it shows in the background when the show/movie is selected?
2. Secondly, I selected the view 'big wide with logos' for the TV shows. It doesn't show the name of show with logos. What am I missing?
Again, thanks for an awesome skin!!
(2015-11-27, 18:48)dibson Wrote: [ -> ]Thanks Guilouz!!
Couple more things:
In next release :
1. Add possibility to choose Fanart transparency in skin settings.
2. Fixed.
Great!
Can't wait for the next release...
New Update 1.0.4 :
Exemple 45% :
Exemple 0% :
Add possibility to choose highlight color opacity.
Add possibility to show media flags on Hub widget.
Add possibility to show clearlogos on Hub widget.
Add translation for fallback widgets.
Remove big wide with logos view with episodes.
Thanks for taking the time to publish your modifications.
I tried 1.0.4 and I seem to be missing the little background boxes on the home screen. The ones around spotlight, and the icons at the top. Maybe I somehow changed an option and broke it myself?
Also, I am using the default, darker color but on the programs screen, it is the "light" screen.
Edit: Nevermind on the background boxes. I found the option to change the appearance. "Header tile style" and "Widgets tile style". My values were blank. Once I selected something it worked.
Edit 2: Disregard my other issue. Maybe it was a Kodi thing, or a caching thing, or an end user thing, but it works as expect now.
Feature Request
If we choose to "individually set in customisation dialog", can we, in the options for that menu item, change the option from a yes/no check to a "never", "always", "on up".
For example, I want the weather option to show the widget posters always, but most of the other items, I want them to be "on up".
Update 1.0.5 :
Add support for unwatched tv show popup from NextUp Notification addon.
Add possibility to choose weather icons addon in skin settings.
Add album wall option for music visualisation background.
Fix up/down controls in skin settings.
Fix labels on necessary addons menu.
Fix genres icons not working.
I done a fresh install of Eminence 2 MOD 1.0.5. Now for some reason I can't get an all black theme. TV shows,Music and programs are all white.
I have the same issue with Eminence 2 MOD 1.0.4. 1.0.3 works fine
Fresh install ? Do you remove addons and userdata folders ?
I have not reproduce this default on a fresh install.
This is because of a possible problem of transparency.
go to settings - and will make this to Default.
Guilouz - This bug I have told you before that conversation between us
Update 1.0.6 :
Add possibility to hide playback information on music visualisation background.
Fix transparency on addons browser.
Fix header tile and widget tile not showing at first install.
Fix default transparency at first install.
Changes in skin settings.
