2016-03-04, 04:05
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
2016-03-04, 05:28
(2016-03-04, 04:05)Guilouz Wrote: [ -> ]What do you mean about widget wrap ?
Sorry that wasn't clear. I just meant the widget list wrapping around. If there is only one unwatched episode for the unwatched episode widget that episode is repeated over and over.....I just think it makes more sense for it to only show up once.
Hope I am being clear.
2016-03-04, 05:44
(2016-03-04, 05:28)Scott00007 Wrote: [ -> ]I think it's a great idea.(2016-03-04, 04:05)Guilouz Wrote: [ -> ]What do you mean about widget wrap ?
@ Guilouz,
Can you please add a wraparound icon start/end for My TV Shows Airing Today widget. Because when there are 7 or more shows airing it can become a bit confusing.
As you pointed out a few threads back the total number of tv shows airing today can not be added to the widget. Alternatively would it be possible to add, for example : 1/5, 2/5, 3/5 to indicate the total tv shows airing today.
2016-03-04, 07:19
Please help, I set up some nice looking .gif icons as my home buttons items, the .gifs work fine on my windows kodi installation, but they do not work with Android installation, any idea how i can use .gif files on Android with this skin??
2016-03-04, 09:03
(2016-03-04, 04:04)Guilouz Wrote: [ -> ](2016-03-02, 09:31)RaZi3L Wrote: [ -> ](2016-03-01, 22:29)RaZi3L Wrote: [ -> ]hello ... I have two problems with the skin.
In the TV channel "info" view... I see the channel logo, and other image below as you can see here:
http://i.imgur.com/2unB4l4.jpg
how can I remove the image below the logo channel?
thx for fix it !
but, what about this ? :
Quote:on the other hand, in the tv channel list there is a white box. When I press ENTER on any channel then I can see it there... but only when I press ENTER... the rest of time I only see a white box...
http://i.imgur.com/6pdTCm5.jpg
How can I set a static image until some channel is selected?:
regards!
Normally I have fixed it on last git.
Thanks Guilouz I was using aeon nox 4.1.9 since 2 or 3 years... until i discovered your mod... now I'm infinitely happier.
2016-03-04, 11:10
Guilouz, could you please add an option to not show icons in the submenu?
2016-03-04, 12:53
(2016-03-03, 20:41)Guilouz Wrote: [ -> ](2016-03-03, 18:21)yakirp88 Wrote: [ -> ](2016-03-03, 09:58)Bonecrusher Wrote: [ -> ]Hey Guilouz,
definitely the best skin mod for now. I got two requests: 1.Can you add an option to replace the clearart in video info screen with the cdart? 2. The bar in the music visualisation always covers the faces of the artists. For me a smaller bar on the bottom would be nicer (like in Madnox).
Thanks a lot for your work.
I asks the first one too. If it's possible to put half disc rotating instead of cleararts it will be lot prettier
No problem for cdarts
EDIT : Available on git
Guilouz I have updated from github and still I get cleararts and not discart
2016-03-04, 13:06
Another question:
Which xml file responsible for the line on home header with the number of shows movies episodes and channels?
I have little problem in it with Hebrew
2016-03-04, 13:22
(2016-03-04, 12:53)yakirp88 Wrote: [ -> ](2016-03-03, 20:41)Guilouz Wrote: [ -> ](2016-03-03, 18:21)yakirp88 Wrote: [ -> ]I asks the first one too. If it's possible to put half disc rotating instead of cleararts it will be lot prettier
You must activate them in skin settings.
2016-03-04, 13:24
(2016-03-04, 13:06)yakirp88 Wrote: [ -> ]Another question:
Includes_Furniture.xml
2016-03-04, 13:27
(2016-03-04, 05:44)Blurayx Wrote: [ -> ](2016-03-04, 05:28)Scott00007 Wrote: [ -> ]I think it's a great idea.(2016-03-04, 04:05)Guilouz Wrote: [ -> ]What do you mean about widget wrap ?
@ Guilouz,
I will see
2016-03-04, 14:56
Thank you for looking into it.
2016-03-04, 16:00
(2016-03-04, 13:22)Guilouz Wrote: [ -> ](2016-03-04, 12:53)yakirp88 Wrote: [ -> ](2016-03-03, 20:41)Guilouz Wrote: [ -> ]No problem for cdarts
i have same issue i disabled claerart and enabled disart in skin setting but still seeing clearart ..love the option to have choice credit for that mate
2016-03-04, 17:13
Hello, please take a look at this video of the .gif images working on the home menu buttons on a windows 10 laptop..
https://www.youtube.com/watch?v=sW1R8aF1t5k
Now any idea why the dont work on an android device like a firestick? What is different I thought Kodi was the media player, not the pc, so why wont it work on android? Please any ideas?? I dont think its a skin issue, just need some help, thanks!
Looks like on android:
http://jed.one/Backgrounds/20160304_085642.jpg
2016-03-04, 17:33
(2016-03-04, 11:10)Alanon Wrote: [ -> ]Guilouz, could you please add an option to not show icons in the submenu?
+1......Would love to see this!!!!
