2016-04-05, 13:09
ya no dice, just replacing the include syntax seems to be not enough. screen stayed black. had to revert back to oe401 the last pre syntax change build. oh well, gonna keep using that one then until skins are updated.
(2016-04-05, 12:37)SkywalkerPD Wrote: [ -> ][I found that the last update breaks the skin because of this:
The final way people decided on in #4876 is flawed. It´s confusing to search for includes, and it´s impossible to write a proper syntax highlighting definition in case lookahead is not supported properly.
This changes the way includes have to be defined by changing the attribute from name="" to definition="".
That way definitions and references can be distinguished easily.
As discussed with @ronie @BigNoid @HitcherUK
Warning: This causes major skin breakage. That can easily get fixed by a search and replace thourgh all files though:
exchange
<EOL><tab><include name=
with
<EOL><tab><include definition=
I tried replacing all include name= with include definition= but that was no succes....
<include content="..."/>
(2016-04-05, 13:42)BobCratchett Wrote: [ -> ](2016-04-05, 12:37)SkywalkerPD Wrote: [ -> ][I found that the last update breaks the skin because of this:
exchange
with
In the end they went, when calling an include with parameters:
Code:<include content="..."/>
not 'definition'. No changes to calling an include without parameters, or when defining an include.
exchange
with
<include name="Object_Line">
<param name="width" value="1880" />
<include content="Object_Line">
(2016-04-05, 00:48)Guilouz Wrote: [ -> ]Sorry I'm working on Estuary MOD. I know Krypton version is broken with latest Kodi build. When I have time, I will update it.
(2016-04-05, 15:52)nuwonda Wrote: [ -> ](2016-04-05, 13:42)BobCratchett Wrote: [ -> ](2016-04-05, 12:37)SkywalkerPD Wrote: [ -> ][I found that the last update breaks the skin because of this:
exchange
with
so should only change includes that are immediately followed by param values, e.g.:
Code:<include name="Object_Line">
changes to
Code:<include content="Object_Line">
rest of the includes remain unchanged. So cant just go in and "replace all"
(2016-04-07, 22:08)MrSeb Wrote: [ -> ]Bonjour à tous
Désole pour mon mauvais anglais. Déjà un grand merci à Guilouz, j'adore ton thème.
Sorry for my bad English. Already a big thank you to Guilouz, I love your theme.
J'ai une erreur quand j'installe Script ExtendedInfo.
I have an error when I install Script ExtendedInfo.
J'ai lu pour avoir la durée des films, il faut mettre à jour Script Skin Helper Service. J'ai la version 1.0.72, mais pas d'info...
I read for the duration of the films, it is necessary to update Skin Script Helper Service. I have the 1.0.72 version, but no info...
Désolé, je suis nouveau sur Kodi ! Merci de votre aide !
Sorry, I'm new to Kodi! Thank you for your help !
C:\Users\username\AppData\Roaming\Kodi\addons\skin.eminence.2.mod-master\16x9
<onunload>ClearProperty(SkinHelper.WidgetContainer)</onunload>
(2016-04-08, 00:53)Sjors125 Wrote: [ -> ]Guilouz made this from Krypton too. See his opening post.
