Full Version: Eminence 2 MOD (DISCONTINUED) - Jarvis & Krypton
Ah, thanks for explaning @ shorty1483
(2016-09-14, 10:33)shorty1483 Wrote: [ -> ]I made some modifications for myself. Perhaps anyone can use it too. Thanks to Giulouz and jurialmunkey for this great skin.
Move Clearlogo above Tile on Homescreen
Removed frame around media flags to get a cleaner look + adding IMDb Top 250 Position in Library and Hub
Removed for me unnecessary buttons + adding an Extendedinfo button in VideoInfo
Changed IMDb Rating with count to IMDb+Tomatometer+Metascore in VideoInfo
Just paste the zipped files in the appropriate directory in skin folder.
https://1drv.ms/u/s!Ai4ct6wPYF8EifF1md10lN0DB2aEvA
Thanks man!
I loved to see the position on imdb..
Great Job!!!!
@ Shorty 1483, I installed your changes now. I like them. Especially the new logo /clear art placement above the just blackbox on the homescreen and not in it.
Thank you very much.
Nice if you guys can use it.
Ok, managed to get CDArt in the video views, but just in the views that make sense to me. You have to activate "Show CDArt" for VideoInfo in Settings.
https://1drv.ms/u/s!Ai4ct6wPYF8EifMVhFQPbP5gxVhEcA Replace Includes_Furniture.xml in /skin.eminence.2.mod/16x9/ with the one from Download. Make backup of the old file just in case.
(2016-09-16, 09:21)shorty1483 Wrote: [ -> ]Ok, managed to get CDArt in the video views, but just in the views that make sense to me. You have to activate "Show CDArt" for VideoInfo in Settings.
NodNodNodNod
Thanks my friend!!!
Continue!!!! Your work is very good!!!
@shorty1483:
you could include that view in the mod?
Your job not to let die this mod, is fantastic!!!
Thanks! Thanks! Thanks!
(2016-09-16, 18:21)naco.proex Wrote: [ -> ]@shorty1483:
Oh, pretty sure I'm not able to accomplish that. My only skills are using my bit of understanding + click and try.
Well, thanks for your work so far. Smile
Thanks friend!
@ shorty1483
is this for Jarvis or krypton
(2016-09-16, 23:23)Sjors125 Wrote: [ -> ]Well, thanks for your work so far. Smile
(2016-09-17, 00:06)Blurayx Wrote: [ -> ]@ shorty1483
For me it worked perfectly in Jarvis.
Jarvis , don't know if it works on krypton...
Gesendet von meinem HTC One M8 mit Tapatalk
I modified the VideoOSD a bit to my delight since the clearart was far to big for me. Additionally I added the Year for movie + more series Info into the Header line. Fixed wrong scaled resolution icon is not on the pic but fixed too.
Since the last small changes were rated good by you guys, I updated the whole zip https://1drv.ms/u/s!Ai4ct6wPYF8EifF1md10lN0DB2aEvA
Hey man, love the changes. I will def use. Would you be able to make a version where the icons/buttons resort back to text!? I struggle to see the icons from far.
Alan
