2016-11-13, 16:33
(2016-11-12, 17:52)gogorman Wrote: [ -> ]Does anyone have the most recent version that works with Krypton?
I was actually going to ask same thing as this wouldn't even install on the latest KODI 17(beta) on ATV4.
(2016-12-03, 23:34)bollstedt Wrote: [ -> ]How can correct this bug and is it possible to change the both strings (last and next) from English into a different language?
Thank you guys
<value condition="!IsEmpty(Window(Home).Property(NextAired.NextDate)) + !Skin.HasSetting(hidenextairedinfos)">[COLOR=$VAR[HighlightColor2]]Next Episode : [/COLOR]$INFO[Window(Home).Property(NextAired.NextTitle),, • ]$INFO[Window(Home).Property(NextAired.AirTime),, • ]$INFO[Window(Home).Property(NextAired.NextDate)]</value>
(2016-12-07, 18:26)dalethefarmer Wrote: [ -> ]Hello, thanks for working on this MOD, I see that is discontinued now, my only request was to add the button below:+1 for this, anyone?
(2016-12-30, 07:26)Veronica Wrote: [ -> ]+1 for this, anyone?
Enviado desde mi Moto X vía Tapatalk!
(2016-12-30, 15:44)Alanon Wrote: [ -> ]Hi, i have version of this skin with some extras like backgrounds, smart playlists; weather widget fixed and mods in Video OSD and live tv, oh and Spanish translations. If you want i can give you the link by PM (github repo)(2016-12-30, 07:26)Veronica Wrote: [ -> ]+1 for this, anyone?
I tried to compare the solution that Eminence 2.5 uses, but I couldn't find anything in DialogSettings that refers to these buttons. If anyone could point me to where to look, I might be able to copy/paste something... I really don't know how to code, so compare, copy, trial and error are my only tools.
Does anyone have a problem where the widget discart suppresses the fanart? Every time there's a disc in the widget, the background fades into blackness. It's really annoying, and I dont know why it's happening. I tried to tinker with it, but no dice...
On a side note, while tinkering I was able to make updates for the latest skin helper service, and also achieved partial support for extrafanart.
(2016-12-30, 20:43)Veronica Wrote: [ -> ]Hi, i have version of this skin with some extras like backgrounds, smart playlists; weather widget fixed and mods in Video OSD and live tv, oh and Spanish translations. If you want i can give you the link by PM (github repo)
When I tested discart widget, everything showed up correctly but i don't use that feature anymore.
watch gallery
<control type="grouplist">
<visible>Control.IsVisible(6)</visible>
<align>right</align>
<right>side</right>
<itemgap>pad</itemgap>
<orientation>horizontal</orientation>
<onleft>6</onleft>
<onright>6</onright>
<onup>6</onup>
<ondown>6</ondown>
<top>-570</top>
<control type="button" id="5">
<width>auto</width>
<height>100%</height>
<texturenofocus>noop</texturenofocus>
<texturefocus>noop</texturefocus>
<focusedcolor>$VAR[HighlightColor]</focusedcolor>
<include>Defs_OptionButton</include>
</control>
<control type="button" id="7">
<width>auto</width>
</control>
</control>
(2016-12-09, 18:55)dalethefarmer Wrote: [ -> ]Hi, I'm using this skin and the youtube adddon only has 3 views, how can I add more? I edited the views.xml to include the panel list 2, but when I select it goes back to list view... Any help?
