Full Version: 15.2 anywhere!
Just wondering if someone with more pi knowledge than me could explain how to upgrade my version.
I've got 14.2 and it keeps popping up saying 15.2 is out.
I tried
sudo apt-get update
sudo apt-get install kodi
but it says:
kodi is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 65 not upgraded.
Any pointers!?!? ;-) Thanks.
I'm using Raspbian
John
Are you on Jessie?
Wheezy is no longer supported so won't get (non-security) updates.
(2015-11-06, 15:12)popcornmix Wrote: [ -> ]Are you on Jessie?
Thanks for letting me know :-) I'm only using that box as a photo viewer, so I'll find a way to turn off the checking for updates instead :-)
