Full Version: Play album without showing track list?
Does anybody know of any setting or addon that makes it possible to skip seeing the track listing all together. What I'm looking for is the ability to play an album just by clicking on it, not pressing the info button or bringing up a list of tracks on the album.
Technically this does only save one click to play an album, however it really does drive be bonkers. Thanks if you can help.
In settings have "play next song automatically" selected, then in the album listing use key "p" or map "play" to the key of your choice.
scott s.
Thanks, I'll look into this. I use a logitech remote so might be able to figure out to keymap this
I'm guessing just using the "play" button will work.
scott s.
