2021-08-24, 18:07
2021-08-24, 22:07
(2021-08-24, 18:07)Shawzborne Wrote: [ -> ]Is this addon still being updated?Yes, what is there to update?
2021-12-31, 18:00
Hey, just a request. Can you add the description of what video is playing on the screen like the Evolve version does. https://forum.kodi.tv/showthread.php?tid=347678
2022-01-02, 11:54
v3.0.3 (2022-01-01)
- New scenes added (Patagonia, Yosemite, Grand Canyon, Iceland, Scotland)
- Updated Apple resources.tar entries.json URL
- Location All is now sorted before any of the other locations
- Fixed bug that was preventing playback or download when HEVC was disabled
https://github.com/xbmc/repo-scripts/pull/2177
Features contributed by kubedzero - Thanks very much!
2022-01-08, 18:37
(2022-01-02, 11:54)enen92 Wrote: [ -> ]v3.0.3 (2022-01-01)Feature Request:
.mov 4K HVEC support for local files
Thank-you for continuing to keep the add-on updated
2022-01-08, 23:48
(2022-01-08, 18:37)Shawzborne Wrote: [ -> ]Feature Request:
Hasn't this been enabled for a long time now?
2022-01-11, 02:03
After updating to v3.0.3 I had a crash when downloading all videos to a working r/w smb folder. Many of the videos were already downloaded and "Enable checksum validation of pre-existing fires" was enabled. The crash did not happen right away, I don't know which video was being downloaded.
Crash message, system details, and /proc/meminfo are at https://paste.kodi.tv/ixujuverut.kodi
If this is just a result of not enough available memory to checksum a particular video, that's fine, but is there anyway to get a little more logging about which file caused the problem?
2022-01-11, 02:17
And thank you _very much_ to both @kubedzero and @enen92 for the screensaver and the recent update.
2022-02-12, 17:37
How to utilize the HDR/4K versions of this? I have boxed both of those, but TV does not seem to switch to HDR mode. It displays those in SDR. Or should I have HDR mode enabled on Windows?
2022-04-14, 11:06
I run it on my Nvidia Shield Pro and it works perfectly. It may be a stupid question, but why does the switch to Dolby Vision work perfectly in your plugin, but not if I try to play some MP4 or MKV files in Kodi that have Dolby Vision in them?
2022-05-08, 21:32
I have a problem with this Aerial Screensaver. It is working fine, but when I want to download videos, it always says to specify a download folder which I already did. Should this download Folder be on an connected Flash Drive or on the internal Flash Drive of my Beelink GT1 Mini Box ?
2022-05-09, 00:39
(2022-05-08, 21:32)bansheeat Wrote: [ -> ]I have a problem with this Aerial Screensaver. It is working fine, but when I want to download videos, it always says to specify a download folder which I already did. Should this download Folder be on an connected Flash Drive or on the internal Flash Drive of my Beelink GT1 Mini Box ?I think that's a known issue with settings update. If you save the setting and close the dialog and then open it again to download the videos it should work.
2022-05-09, 10:49
Okay thank you, I will try that.
And it worked, thanks
2022-06-07, 22:55
Do the 4K HDR files support Dolby Vision AND standard HDR, or are they Dolby Vision only? Just wanted to verify before I download all of the videos so I know if the HDR versions will work on my Windows htpc.
2022-06-08, 01:36
Dolby Vision videos should fallback to HDR on non-DV supported devices.
