Full Version: Aerial (ATV4 Screensavers)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
How many videos are there? I'm downloading for offline mode and am on b9-2.mov and I'm wondering how much more I have to go?
Sent from my 0PM92
Oddly enough I am able to play the videos on their own (both in Kodi and in VLC) but when it comes to playing them as a screensaver they freeze. :/
I'll have to reserve the files and hope my next kodi box will be strong enough to play these.
(2016-04-11, 15:12)ashlar Wrote: [ -> ]http://a1.phobos.apple.com/us/r1000/000/...tries.json
Here is the complete list.
Use the version in GitHub?
Enviado do meu A0001 através de Tapatalk
EDIT: Nevermind. After doing a fresh reinstall of OpenElec, and trying out ATV4 screensaver before installing any third-party addons, the screensaver works fine. After installing a particular package of addons that is not allowed to be mentioned here, the screensaver locked up again. So it has something to do with one or more third-party addons that are causing the failure of the ATV4 screensaver to function properly. I just now have to go through the tedious process of finding out which addon or addons is the culprit.
Hey, I bought one of these chinese boxes, not to be named, full of tese, not to be named addons, for a friend of mine. Did you ever find out the problem one? Im having some similar issues and now manually downloading ideos and testing again. Thanks for the nice screensaver etc Cool
Thank you for this.
Finally sent an update to the official repository to sync it with the version in github (1.3.2), it should be available in the next couple of days.
Added checksum verification for the files downloaded to avoid downloading all the videos again (tks graysky2).
Also changed the name to Aerial (same addon.id though so no changes will be noticed).
Cheers
I created an AUR package for this software for Arch Linux users: https://aur.archlinux.org/packages/kodi-...ple-aerial
Issue:
Using party mode with artist slideshow addon - the screensaver will turn on and "override" artist slideshow.
Pressing any button will then turn off the screensaver and also turn off party mode.
(happens e.g. with Metropolis skin)
Did anyone solve the hanging/freeze issue?
(2016-07-01, 11:47)VelvetKevorkian Wrote: [ -> ]Issue:
Could not reproduce but please check your screensaver settings: http://kodi.wiki/view/Settings/Appearance#Screensaver
You probably are using this screensaver when playing music instead of a visualization
I iv'e got a problem this is the last logg :
01:01:47 T:1522394032 DEBUG: ATV4 Screensaver player has been created
01:01:47 T:1946034752 DEBUG: Loading settings for /home/pi/Downloads/screensaver/b10-2.mov
01:01:47 T:1946034752 DEBUG: CPlayerCoreFactory::GetPlayers(/home/pi/Downloads/screensaver/b10-2.mov)
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/mms/udp
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
01:01:47 T:1946034752 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
01:01:47 T:1946034752 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
01:01:47 T:1946034752 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
01:01:47 T:1946034752 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
01:01:47 T:1946034752 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
01:01:47 T:1946034752 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
01:01:47 T:1946034752 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
01:01:47 T:1935668144 DEBUG: CAESinkPiBig Grinrain delay:100ms now:0ms
01:01:47 T:1935668144 DEBUG: CAESinkPiBig Grineinitialize
01:01:47 T:1935668144 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000000
01:01:47 T:1935668144 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.audio_render handle 0x72c7f3c8
01:01:47 T:1946034752 NOTICE: DVDPlayer: Opening: /home/pi/Downloads/screensaver/b10-2.mov
01:01:47 T:1946034752 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
01:01:47 T:1946034752 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
01:01:47 T:1946034752 DEBUG: CMMALRenderer::UnInitMMAL pool((nil))
01:01:47 T:1946034752 DEBUG: CMMALRenderer:TonguereInit
01:01:47 T:1589502896 NOTICE: Thread DVDPlayer start, auto delete: false
01:01:47 T:1589502896 NOTICE: Creating InputStream
01:01:47 T:1589502896 DEBUG: ScanForExternalSubtitles: Searching for subtitles...
01:01:47 T:1589502896 DEBUG: ScanForExternalSubtitles: END (total time: 1 ms)
01:01:47 T:1589502896 NOTICE: Creating Demuxer
01:01:47 T:1589502896 DEBUG: Open - probing detected format [mov,mp4,m4a,3gp,3g2,mj2]
01:01:47 T:1589502896 DEBUG: Open - avformat_find_stream_info starting
01:01:47 T:1589502896 DEBUG: Open - av_find_stream_info finished
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/pi/Downloads/screensaver/b10-2.mov':
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: Metadata:
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: major_brand : qt
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: minor_version : 0
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: compatible_brands: qt
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: creation_time : 2015-12-01 01:03:46
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: Duration: 00:03:12.23, start: 0.000000, bitrate: 5940 kb/s
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 5937 kb/s, 30 fps, 30 tbr, 30030 tbn, 60060 tbc (default)
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: handler_name : Core Media Data Handler
01:01:47 T:1589502896 INFO: ffmpeg[5EBDE3B0]: encoder : H.264
01:01:47 T:1589502896 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
01:01:47 T:1589502896 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x530c71d0
01:01:47 T:1589502896 DEBUG: OMXClock::OMXStop
01:01:47 T:1589502896 DEBUG: OMXClock::OMXSetSpeed(0.000) pause_resume:1
01:01:47 T:1589502896 NOTICE: Opening stream: 0 source: 256
01:01:47 T:1589502896 DEBUG: DllBcm: Using omx system library
01:01:47 T:1589502896 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131 m_handle 0x530dd600
01:01:47 T:1589502896 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - port(130), nBufferCountMin(1), nBufferCountActual(120), nBufferSize(81920), nBufferAlignmen(16)
01:01:47 T:1589502896 DEBUG: COMXVideo::Open - decoder_component(0x0x530dd600), input_port(0x82), output_port(0x83) deinterlace 1 hdmiclocksync 1
01:01:47 T:1589502896 INFO: OMXPlayerVideo::OpenDecoder : Video codec omx-h264 width 1920 height 1080 profile 100 fps 30.000000
01:01:47 T:1589502896 NOTICE: Creating video thread
01:01:47 T:1589502896 ERROR: Get - failed to get stream
01:01:47 T:1469051824 NOTICE: Thread OMXPlayerVideo start, auto delete: false
01:01:47 T:1469051824 DEBUG: COMXPlayerVideo - CDVDMsg:TongueLAYER_STARTED 0
01:01:47 T:1589502896 DEBUG: ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: /home/pi/Downloads/screensaver/b10-2.mov
01:01:47 T:1589502896 DEBUG: OnPlayBackStarted: play state was 1, starting 1
01:01:47 T:1589502896 DEBUG: CDVDPlayer::SetCaching - caching state 3
01:01:47 T:1589502896 WARNING: CDVDMessageQueue(audio):Tongueut MSGQ_NOT_INITIALIZED
01:01:47 T:1946034752 DEBUG: PlayFile: OpenFile succeed, play state 2
01:01:47 T:1469051824 DEBUG: COMXPlayerVideo - CDVDMsg:TongueLAYER_SETSPEED 0
01:01:47 T:1946034752 DEBUG: OnPlayBackStarted: play state was 2, starting 0
01:01:47 T:1589502896 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
01:01:47 T:1522394032 DEBUG: ATV4 Screensaver player has started. Toggling repeatAll
01:01:47 T:1469051824 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(-4503599627370496.000000, 0.000000, 1)
01:01:47 T:1469051824 INFO: COMXPlayerVideo - Stillframe left, switching to normal playback
01:01:47 T:1469051824 DEBUG: OMXVideo:Big Grinecode VDec : setStartTime 0.000000
01:01:47 T:1589502896 DEBUG: CDVDPlayer::CheckContinuity - wrapback :2, prev:66666.666667, curr:33333.333333, diff:-33333.333333
01:01:47 T:1469051824 INFO: Output - renderer not started
01:01:47 T:1946034752 DEBUG: ------ Window Init (VideoOverlay.xml) ------
01:01:47 T:1589502896 DEBUG: CDVDPlayer::HandleMessages - player started 2
01:01:47 T:1589502896 DEBUG: CDVDPlayer::HandleMessages player started RESET
01:01:47 T:1589502896 NOTICE: OMXClock using video as reference
01:01:47 T:1589502896 DEBUG: OMXClock::OMXReset audio / video : 0 / 1 wait mask 0->2 state : 2->1
01:01:47 T:1589502896 DEBUG: CDVDPlayer::HandleMessages player started 2 (s:1000 a:0 v:1)
01:01:47 T:1589502896 DEBUG: CDVDPlayer::SetCaching - caching state 0
01:01:47 T:1469051824 DEBUG: COMXPlayerVideo - CDVDMsg:TongueLAYER_SETSPEED 1000
01:01:47 T:1946034752 INFO: Previous line repeats 1 times.
01:01:47 T:1946034752 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
01:01:47 T:1946034752 ERROR: COMXImageFile::ReadFile /home/pi/.kodi/addons/screensaver.atv4/resources/skins/default/media/black.jpg GetCodingType=0x7fffffff
01:01:47 T:1946034752 NOTICE: LoadJpeg: unable to load /home/pi/.kodi/addons/screensaver.atv4/resources/skins/default/media/black.jpg
01:01:47 T:1589502896 INFO: Previous line repeats 19 times.
01:01:47 T:1589502896 DEBUG: CDVDPlayer::OMXDoProcessing Resume -4503599616.00,0.70 (A:01 V:01) EOF:0 FULL:0 T:0.20
01:01:48 T:1883239344 INFO: Previous line repeats 93 times.
01:01:48 T:1883239344 ERROR: COMXCoreComponent:Big GrinecoderEventHandler OMX.broadcom.video_decode - OMX_ErrorInsufficientResources, insufficient resources
01:01:48 T:1946034752 ERROR: Previous line repeats 4 times.
01:01:48 T:1946034752 DEBUG: CGUIInfoManager::SetCurrentMovie(/home/pi/Downloads/screensaver/b10-2.mov)
01:01:48 T:1946034752 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
01:01:48 T:1946034752 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
01:01:48 T:1946034752 DEBUG: UPnP: Building didl for object '/home/pi/Downloads/screensaver/b10-2.mov'
01:01:48 T:1946034752 DEBUG: CAnnouncementManager - Announcement: OnPropertyChanged from xbmc
01:01:48 T:1946034752 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPropertyChanged
01:01:48 T:1946034752 ERROR: Previous line repeats 14 times.
01:01:48 T:1946034752 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
01:01:56 T:1946034752 ERROR: Previous line repeats 362 times.
01:01:56 T:1946034752 ERROR: CPythonInvoker(22, /home/pi/.kodi/addons/screensaver.atv4/atv.py): script didn't stop in 5 seconds - let's kill it
01:01:57 T:1883239344 ERROR: COMXCoreComponent:Big GrinecoderEventHandler OMX.broadcom.video_decode - OMX_ErrorInsufficientResources, insufficient resources
01:02:16 T:1849684912 ERROR: Previous line repeats 893 times.
01:02:16 T:1849684912 DEBUG: Thread JobWorker 1849684912 terminating (autodelete)
01:02:16 T:1883239344 ERROR: COMXCoreComponent:Big GrinecoderEventHandler OMX.broadcom.video_decode - OMX_ErrorInsufficientResources, insufficient resources
I don't understund why that say "insufficient resources" cause i can open the .mov with Kodi by the Desktop someone can help me ?
i've got pi3 with freq800 and gpu_mem256
Ok nice it work after an rpi-update
nice addon but high cpu usage and higher cpu temps on rpi2. Thats NOT a screensaver, its just running an video, no energy saving.
