Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Ooh looks nice, thanks! Too bad the AFTV screensaver takes over after a while...
many thanks for this great addon , but I have a problem , I set my HTPC to go into standby after 15 minutes , however with this addon is always on !!!! no solution ? sorry for my bad English . thank you.
Just tried it on my 15.2 and it's really lovely! Thanks!
[EDIT] Oops, I didn't wait... for me it can't exit the screensaver, after it's launched, if I press any key the screen just turns black. I can hear the UI sounds, but I don't get the UI back.
Has anyone put this on the Nvidia shield or some other android TV device?
(2015-11-16, 20:47)krakout Wrote: [ -> ]Just tried it on my 15.2 and it's really lovely! Thanks!
The addon starts a video playlist you have to stop the playing video.
Ah I see, but not even "back" on the remote works... as I said, the screen turns black, obviously the UI has come up because I can hear its sounds and nothing else.
(2015-11-19, 12:45)krakout Wrote: [ -> ]Ah I see, but not even "back" on the remote works... as I said, the screen turns black, obviously the UI has come up because I can hear its sounds and nothing else.
Can you post a full debug log?
Also some info about the platform (and OS) you are running kodi on would be great
Blank screen on Jarvis nightly when testing this screensaver
http://xbmclogs.com/phedljilm
EDIT: Seems to be working now, guess the dark screen was it downloading?
Yeah I'm preventing the screensaver to be displayed if the idle time is lower than the time set for the screensaver to prevent it from starting over and over again. But that is probably not correctly done since it blocks the preview of the screensaver.
Guess I need to find another approach to make it 100% workable. Right now it only works when activated from kodi (> time). I guess that when the addon is grabbing the list of videos kodi is calling the screensaver multiple times.
Yep that makes sense, would be good to get it working with preview mode, if only so we can show it off
Maybe i'm biased, but this is so beautiful!
Yeah london by night is my default screensaver as well. China ones are beautifull too.
Maybe I will redesign it a bit and disable the video osd. Maybe a window xml that contains only the player would be better. Then any detected keystrokes would kill the screensaver. Problem is, we would not be able to move between videos on the playlist but this is a screensaver anyway. What do you think? Should I leave it as it is or change it?
The preview stuff is doable without changing the window. The only reason I don't want to have a bunch of work with this screensaver is because the addon is using the apple API and we never know how long it will last without they breaking it.
To me a screensaver should be totally automatic with no controls. But thats just me
Ok I'll re-write it tonight. The settings are also a bit crappy right now
