(2016-05-24, 20:45)marcelveldt Wrote: [ -> ] (2016-05-24, 09:33)epicfail Wrote: [ -> ]Wooohooo bug is fixed with new Beta and Skin Helper Version....thanks a lot marcelveldt and mikesilvo164
Never thought that that fix was going to work, apparently it did :-)
Never?!?
My wife is usually mad at me cause she says I am correct far too often...
@marcelveldt
is it planned to add some compatibility options for Emby CoverArt plugin? Just tried it and unfortunately the covers don't look pretty well, because the bigger borders of the original Titan covers are still visible
Or could you please tell me where I can find the parameters of the border size to adjust it myself?
(2016-05-24, 21:30)urzahil Wrote: [ -> ]How do I get rid of the white band on some widgets?
You may enjoy the weather widget more if you set the widget's layout to "square".
(2016-05-25, 13:23)horstepipe Wrote: [ -> ]@marcelveldt
I will add in a fix for this tonight. If I remember correctly I can detect from the image path if coverart is enabled or not.
(2016-05-24, 21:36)marcelveldt Wrote: [ -> ] (2016-05-24, 21:25)oattes Wrote: [ -> ]Just as a data point, I can definitely see the effect on the horizontal layout widgets. It's very modest but noticeable. I think if you wanted this to 'stand out' a bit more, you'll have to make the widget strip take up some more room from the info panel. I did not try it on other layouts where the effect may be more pronounced.
In that case there will not be enough space left. It's all pretty compact to place as much widgets as possible on the screen.
It's not just that there will not be space left -- there is not enough space now ;-). Note the following screen shots:
-> highlight border is touching the poster image above
-> actually over top of the line detail at the bottom of the panel
(2016-05-25, 17:09)oattes Wrote: [ -> ]It's not just that there will not be space left -- there is not enough space now ;-). Note the following screen shots:
That was actually what I meant to say ;-)
I think it will better fit with the other widget layouts
(2016-05-25, 17:23)marcelveldt Wrote: [ -> ] (2016-05-25, 17:09)oattes Wrote: [ -> ]It's not just that there will not be space left -- there is not enough space now ;-). Note the following screen shots:
Yes, but you should (IMHO and you know how pixel perfect I can be ;-) keep the Vermeer like quality of the skin
It's payback for the large diversity of views that you have built to be cursed with the need to make all new features fit (perfectly) all of the skin options. Of course, I'm sure the original requester was just thinking of their own preferred view ... ain't being a developer grand?
@marcelveldt: at the risk of being "that guy"... did you see my previous message/video (#1830) re: scrolling with a touch interface?
(2016-05-25, 20:42)nuentes Wrote: [ -> ]@marcelveldt: at the risk of being "that guy"... did you see my previous message/video at the end of page 122 re: scrolling with a touch interface?
You should reference post numbers because custom page lengths can be set.
(2016-05-25, 23:25)diedrichg Wrote: [ -> ] (2016-05-25, 20:42)nuentes Wrote: [ -> ]@marcelveldt: at the risk of being "that guy"... did you see my previous message/video at the end of page 122 re: scrolling with a touch interface?
post 1830
updated on my other post as well - thanks diedrichg
Need help. Trying to have Youtube display icons/posters. Mine is a scroll bar, which is hard to navigate.
v3.6.66
I was playing around with a fresh beta install and, without disabling or modifying any features, I was checking out Netflix2 homescreen and noticed this overlap in the top right corner:
Latest beta v3.6.66
I'm getting a mysterious "5" PVR artwork (actually I think its the ex-logo for Channel 5, they changed it a while ago) appear where it shouldn't. For example:
watch gallery
(bottom right of the first two, in the thumbnail of the third)
None of these programmes were even recorded on 5 as you can see. I'm not actually where sure it got that image from. Any idea?
(2016-05-24, 23:35)rickmans2 Wrote: [ -> ]The skin txt file has every where spmc links to the pictures from the addons!
So the don't have special links ( special://home/)
If I make my build in spmc I cant load it in to kodi onze my otter device then I Will not see the pictures from the addons!
Use the skin's builtin backup feature, that will solve the issue as it will "convert" the paths for you to special:// and include the images in the backup.
