Hey everyone.
Have two Kodi boxes one still running Titan 3.6.59 the other running Titan 3.6.71.
I have a Single Box widget configured for both my TV Shows and Movies shortcut on my home screen. They work fine in 3.6.59 but once my other box upgraded to 3.6.71 they are not showing up. Anyone else having this issue?
(2016-06-27, 04:59)JSAKelley Wrote: [ -> ]Hey everyone.
i have the exact same issue my firend and im gutted as i love this view
can you maybe link me to a copy of 3.6.59 please while marcel works on fixing this issue ?
(2016-06-27, 13:46)dgreenmon Wrote: [ -> ]i have the exact same issue my firend and im gutted as i love this view
Here is a link I found. Can't verify it works because I'm at work and it's being filtered out.
http://mirrors.kodi.tv/addons/jarvis/skin.titan/
Is the PVR artwork for Live-TV working correctly in Skinhelper Service .98 ? I am not sure if it is my configuration or the addon, maybe someone can verify this.
(2016-06-25, 15:43)malvinas2 Wrote: [ -> ] (2016-06-21, 21:23)marcelveldt Wrote: [ -> ] (2016-06-20, 22:25)malvinas2 Wrote: [ -> ]During the playback the OSD doesn't show the cdart and there is no logo in the upper right corner.
Issue reproduced and fixed. I'll upload new beta of skinhelper later today.
It's working in .98.
Minor bug: I noticed that the fanart in the artist and album view is cycling, although extra fanart is deactivated in the context menu.
@marcelveldt - Titan updated for me, and the scrollbar is now bigger (thanks for that!). However, it still takes a lot of precision for me to grab it. I can grab it far more reliably, but I'd say it still often takes 3 or 4 tries. Is there anything further that can be done?
(2016-06-24, 17:46)MediumME Wrote: [ -> ]Yes, also tried re-assigning the widgets.
Automatic updates are enabled. Checked for updates manually as well.
Every addon is up to date.
Uploaded my backup file here: http://uploaded.net/file/pkmx84zu
Thank you for looking into it. Have a Beer on me
Thanks for the beer!
I've tested with your backup and the widgets are working for me.
Strange!
Can you try to make a backup of your Kodi userdata folder, install Kodi fresh with the Titan skin and import this backup ?
Maybe something wrong with your setup atm.
[quote='dgreenmon' pid='2364035' dateline='1466807907']
I have recently run into a issue with the skin view "single box" this is by far my favourite view but the other day i loaded up kodi and the no icons, fanart, product info nothing is there, i can see the categories but i can not see any tiles etc they are there as i can click them blind folded, i have tried this on several devices from scratch, i cant figure out what the issue is i dont know of any dependenices that have updated i thought it may be skin helper services so i rolled back to a older version but no joy i cant see anything in the log except from
/quote]
I assume you are talking about the "Single Box" widget layout ?
What homescreen layout are you using ?
I just found out that the single box widget is not working for the Titan tiles and horizontal homescreen layouts at all. Not sure if you're talking about the same issue here. Anyway I'll fix this issue in the next update. Please let me know what homescreen layout you're using to be sure we're talking about the same issue here.
Hello,
What does "enable widget force refresh" do and how do I perform it?
(2016-06-25, 08:29)rangeyrover Wrote: [ -> ]First of all a thank you for your fine work. I use this on a 65" Tv and a 7" tablet. The ability to use on both is incredible.
For the 7" touch screen display which is for a CarPC media centre, In most ways its perfect with touchscreen support and big buttons on the home screen.
I'm trying to change the button sizes on the OSD though as they are the only ones that are still a bit too small.
I would like to have larger button on the OSD , I have selected rounded icons in OSD Extra Large, but they are still too small really for a 7" display.
I have been looking around the XML files to try and find the source files to attempt to modify, but even when I modify an area it does not seem to have an effect.
Please could you point me to the files that need to be modified to affect the OSD in Full screen music player and for the top OSD when in Home screen but music still playing.
RR
First of all: bad idea to modify the xml files. Your changes would be overwritten with every skin update and you have a chance to corrupt the entire skin if you overwrite your changes if there was some refactoring in the skin code.
Better to propose a change here on the forums (feature request) or submit code to me so I can include it in the skin. Others can than benefit from your ideas and your changes won't be lost with skin updates. In fact, the entire skin is what it is now because of the input of all users around here.
That said, your request to make the OSD buttons even larger.Well that's not going to be easy because the way I see it now all space is already utilized by the big buttons, there is no space left to make them even larger. BTW: the current big OSD buttons were added for purpose of using it on a small touch screen (e.g. in a car).
What I can do is add an XXL option but that would mean that some info will be dropped of the OSD such as the finish time and the progress bar.
(2016-06-25, 15:43)malvinas2 Wrote: [ -> ]Minor bug: I noticed that the fanart in the artist and album view is cycling, although extra fanart is deactivated in the context menu.
Which view is having this issue ?
The disable extrafanart option in the sideblade menu is view-dependant.
The last row (6) of the mini-guide is only a "half" row which can't really be read/used. Can i adjust the number of rows in the mini-guide for e.g. to 5?
(2016-06-25, 20:52)XBMCWorkstation Wrote: [ -> ]Little problem: In the actual stable (.71) the tags in the music library are always visible, even if I disable them ....
Will be fixed in next update.
(2016-06-25, 23:38)loggio Wrote: [ -> ]Slim List View in addons doesn't show download progress percentage.
Also doesn't show "version number" or "enable" status.
Not really a bug but it wasn't implemented in that view. Anyway, I've just added it. Available in next update.
(2016-06-26, 06:42)alfio Wrote: [ -> ]Hi Marcel, I'm using the stable version (6.71) and this problem is still happening: http://imgur.com/a/86wHj
That's because the stable skin was updated just before I applied this fix. I will update the stable version once again this weekend so some more bugs will be squashed.
