(2016-07-29, 19:09)amshpitz Wrote: [ -> ]I repeat my first request if it is difficult to make parameter
I would like the names of XML and rows to update.
I want to reduce the lines (buttons).
I want to reduce the space between lines (buttons), where I do it, what XML and line?
Thanks in advance
Be patience please. As discussed earlier this week I will add the option to set the heigth as a skin option.
Are you running the beta of the skin ?
I'm using the Titan skin as one of my first that attracted my attention. Since yesterday I have a problem and "lost" two tiles on the home screen. I see them in the menu shortcuts, but they don't appear on the home screen anymore? When I restore a backup they don't come back either.... I don't know what I'm doing wrong, but I hope it can be restored or else I have to install everything again from scratch. It took a lot of time to get everything the way I wanted, but it's all lost now.... Hope someone can help me out here.
I'm getting errors in the log from skinhelper. I'm running Titan v 3.6.71. Any idea what might be causing these?
http://pastebin.com/dysAnG3R
I cannot get the extended script info to show the left sidebar menu that I see when I use confluence. Please help!
Anybody know how, when using the "Enable Square Submenu" option, to get the label of the submenu item to show up on the home screen?
Bug with the Subtitles dialog:
The text is out of the dialog
After montha of using this skin ik finally happy with it. I know my way around and can set up everything inl want on it yet inhave noticee one thing thats bothering me....its a silly one.
Im now using the low horizontal menu with single widgets. The menus look great with square and landscape widgets but if i have small posters then it doenst line up where the square and landscape one are. The row of small posters is higher up on the screen.
I saw the skin has been updated. Is there any update on the size of a button on the main menu?
(2016-08-01, 13:06)amshpitz Wrote: [ -> ]I saw the skin has been updated. Is there any update on the size of a button on the main menu?
Its available in the beta version of the skin.
Excellent but there is a bug
after closing the kodi and reopened it is return to default settings of the button in the main menu.
(2016-07-21, 20:57)marcelveldt Wrote: [ -> ] (2016-07-16, 04:47)jsnj Wrote: [ -> ]Yes. I just came to this thread to report that, having just come back to using Titan. There currently is no way to quickly see the enabled/disabled status of timers in a list. Used to be green = enabled, no icon = disabled, and red = recording active. Marcelveldt, is that a bug or by design? RFE to bring them back or some timer status overview like Confluence or Mimic`s text descriptions so we don`t have to click on each individual timer to see the status. Thanks for your work on this terrific skin.
It seems to be a bug which I will fix for the next skin update
Received an update to v3.6.78. Still no timer status icons.
New Bug. In the homescreen layout settings section, I can`t use the up/down arrows on the remote to move between "homescreen layout" and "default position to focus in home menu".
(2016-07-30, 03:33)78suited Wrote: [ -> ]I'm using the Titan skin as one of my first that attracted my attention. Since yesterday I have a problem and "lost" two tiles on the home screen. I see them in the menu shortcuts, but they don't appear on the home screen anymore? When I restore a backup they don't come back either.... I don't know what I'm doing wrong, but I hope it can be restored or else I have to install everything again from scratch. It took a lot of time to get everything the way I wanted, but it's all lost now.... Hope someone can help me out here.
Which two tiles are missing ? Try to remove them in the shortcuts editor and add them back.
(2016-07-30, 14:17)patpend Wrote: [ -> ]I'm getting errors in the log from skinhelper. I'm running Titan v 3.6.71. Any idea what might be causing these?
Yes, you try to use some features in the skin that do not yet exist in the repo version of the skinhelper script.
The update of the script is waiting for submission on the repo so just wait and it will resolve itself.
(2016-07-31, 07:12)lowkee00 Wrote: [ -> ]I cannot get the extended script info to show the left sidebar menu that I see when I use confluence. Please help!
Small bug in the skin. Will be fixed in next (beta) update.
