2016-03-14, 17:07
(2016-03-12, 00:26)PixelJunkie77 Wrote: [ -> ]Is there any chance you can add a Kodi Jarvis background to the default background images
If you (or someone else) provide me with the background image I will include it, no problem.
(2016-03-12, 02:11)mrojc Wrote: [ -> ]hey is it a new repo for kodi and a new skin helper?
(2016-03-12, 03:47)benrita Wrote: [ -> ]Auto update to 3.6.43 and Biglist 2 view has changed. Poster is now on far right and if info panel in centre the disc art hides alot of it.
Before you could have poster in centre and move info panel to far right, now info panel only moves from left hand side to the centre.
Is this now the standard for Biglist 2 ?
(2016-03-12, 18:55)mihawk90 Wrote: [ -> ]This happens when I send Kodi from my main monitor (1920x1080) to my second monitor (1440x900) with the windows (Win + Shift + Right /Left) shortcut. When I send it back to the main monitor, the spinning disc is fine again, I suspect it doesn't redraw/recalculates the layer when I switch it over, everything else in the skin seems to be fine with it though.
(2016-03-12, 21:16)oattes Wrote: [ -> ]I'm not seeing this problem generally, but what I am seeing is that once I move into a music library based widget, the background fanart freezes on the image for the widget selection. When you leave the widget an return to the home screen menu the background stays frozen even when you move to another tile -- unless that tile has a set of (non music library based) widgets in which case the fanart background starts cycling again. If further information or illustration is required, let me know and I can provide it.Should be fixed in next beta.
(2016-03-13, 02:09)mihawk90 Wrote: [ -> ]You now have to disable this directly in cu.lrc's settings, it's annoying but at least now it's consistent across skins.
(2016-03-13, 12:59)mo711 Wrote: [ -> ]I translated about 40 German language strings in Transifex now. But there are still more than 100 untranslated strings to do.
Could you update for next release the German language file?
By the way: your Titan skin is amazing! Great work!
(2016-03-13, 16:20)VMCosco Wrote: [ -> ]Having an issue with the Favourites widget...I am running on a Fire TV and my Favourites are all selections from "Android apps" that I have installed on my Fire TV (WatchESPN, Netflix, etc) so that I can just open them from within Kodi. I have the Favourites widget set for the "Add ons browser" menu item. The favourites and icons show up but clicking on them does not open the corresponding app.
As an aside (and maybe a helpful point), one of my Favourites is to the Android app for my Fire TV Spotify app. I added this Spotify "shortcut" item as a Home Menu item. It works great. Clicking the item opens the app.
(2016-03-13, 17:49)ahorne82 Wrote: [ -> ]Kodi 16
Netflix home screen
Not sure if anyone else is having problems but since last update I have had numerous issues with kodi becoming unresponsive and crashing. The only way to get out of this is to press home button and force close kodi then restart. I have been running this setup without any issues for a while so assume it must have something to do with the update
(2016-03-13, 22:33)Simograndi Wrote: [ -> ]this is my log, I hope it may be useful to understand why it takes ages to load music widgets and backgrounds (which worked fine since some time ago). I'm running Jarvis 16.1 RC1 on Windows10, latest beta of TitanI've been working on code optimizations last couple of days and it's all solved now. Thanks for the log.
(2016-03-13, 22:33)Simograndi Wrote: [ -> ]- Home LY > Widget auto rotate > most options and descriptions in the config popup windowOh right, I still need to append those to the language file. Will do so right away so they'll appear in transifex within a couple of days.
- Home LY > Show labels on widgets > all options except for "Disable"
- Configure Shortcuts > "Restore menu items" and it's popup message
- Configure Shortcuts > Menu shortcuts editor > "Restore menu items"
- Configure Shortcuts > Menu shortcuts editor > Eg. Change Shortcut > "Choose item for menu" popup header
- Configure Shortcuts > Menu shortcuts editor > Widget section > Layouts options names
- Configure Shortcuts > Menu shortcuts editor > Widget section > widgets labels options names and description (same as above?)
- Background settings > "Conditional background override" title and below setting + setting popup texts
- Playback & OSD > most text of options (the ones showing at right as enabled option). This in general aren't translated overall into the skin
- Themes > "Manage Color Themes"
In general aren't translated all background/widgets names which aren't default ones (is this doable?) and the color names (maybe this is better they're a lot!)
(2016-03-13, 22:33)Simograndi Wrote: [ -> ]- since last beta the "show info at right" option doesn't work properly for big list / big list 2Will be fixed in next beta
- In the "skin setting" quick window accessible from the library, the "supported addons" page is empty. Also with touch it's hard to scroll low flags.
(2016-03-14, 02:57)oattes Wrote: [ -> ]Update: With the extra fanart turned off the backgrounds in the music library are much more well behaved (In about 50 tries, I only got a background 'delayed' sequence playing twice and only when I really moved through about 30 artists very quickly). However the logos still show the same behaviour as the extra fanart. Moreover, if I run through a list of artists quickly and then return to the home screen (with the music tile selected) I see the background 'delayed' sequence play there! This really feels like a processing queue is being established for the background handling worker thread (skin helper?). The work queue should only have a single artist in it any any time -- if the artist selection changes while the worker queue is finding and (eventually) displaying (extra) fanart the work queue should be reset and the newly selected artist provided to the worker thread. Forgive me for speculating as to how the background processing is handled, of course, but this might explain what I am seeing.
(2016-03-14, 13:07)diedrichg Wrote: [ -> ]I remember you saying it was fixed but in this particular view (Big Panel Wall) I do not get a focus. I can't use my controller's D pad nor can I use a phone app such as Kore.
(2016-03-14, 16:37)Seanh87 Wrote: [ -> ]Hi sorry if this isn't in the right place, after a few times in and out of kodi the skin seems to crash and cancel all my sub menus, thumbnails etc
