2015-11-13, 06:17
Howdy,
So I decided to setup Kodi on my Mac Mini (2011) and hide my old machine with its mountain of HDDs in another room, and build my library over SMB. It's worked in the past for me, but I"m having a huge amount of trouble with 15.2.
First I had problems with the skin I'm using (Experience1080) not being able to access the settings menu, so I had to go and delete my settings file and reset it all. Got that sorted.
Then I was unable to add movies due to TMDB updating their API and breaking Kodi's parse regex. Initially I tried using a different scraper, but kept getting crashes, so I switched back to the default one and manually applied a fix to get that working. No crashes since with movies.
Now it's crashing adding TV shows.
kodi.log http://xbmclogs.com/plkaygfe9
osx crash trace http://xbmclogs.com/piblscfoc
Ideas?
Ideas?
