Full Version: How Do you change Nav Bar Font Colors
Can't seam to find a way to change the roll over font colors on the Main Nav Bar inside Kodi.
what xml file controls the rollover states Colors for the Main Nav Bar
thank you for any help you can give me!
at a quick look start here
https://github.com/xbmc/xbmc/blob/master...uItems.xml
then youre looking for 'ButtonHomeSubCommonValues'' as one button type, then within that which is here https://github.com/xbmc/xbmc/blob/6afd49...cludes.xml
then these
<textcolor>grey2</textcolor>
<focusedcolor>white</focusedcolor>
<texturefocus border="5">HomeSubFO.png</texturefocus>
<texturenofocus border="5">HomeSubNF.png</texturenofocus>
