Full Version: Pannings are jerky
Hello,
I just tried Kodi vs MP1
Everything is ok: live TV, recording, scheduling, epg...
But it looks like the frame rate in live TV is not stable. Same scene that was jerky during live TV, is smooth when recorded.
This is particularly visible during pannings, when, very often, it seems that the camera jumps few frames backwards, or stops then skips few frames to catch-up.
Sometimes, the image is ok, but there are few ms of sound that are cut.
When it happens, playing back the same scene with timeshift, supresses the glitch that just happened.
So I guess this is not an issue with the TV server. It does not happen with MP1 client anyway.
I found very few settings to play with: enable/disable Vsync ? It does not help.
Any Hint ?
Regards
Good morning,
I encountered the same problem and I can not figure out which setting to use for a display without any frame loss.
I also with the client mediaportal I show up without interruption, linear.
Any suggestions?
Thank you.
