Full Version: Aeon MQ 6 - Moded version for I, J, K, L, ....
Leia Version 6.13.2 MOD (12/1/2019):
https://github.com/Angelinas1/Aeonmq6-Leia
New Moded version of AeonMQ6 for Krypton...
(original version by MarcosQui)
https://mega.nz/#!fNIE3BSD!W1TodBGWbLHXC...7ejOecMsSQ
Thank you Marcos for wonderful skin. I moded some thing hope they take place in new AeonMQ7....
Download link for version (Krypton) ,without texture.xbt is on Github
https://github.com/Angelinas1/Aeonmq6-Krypton
for texture please download manual and paste in skin folder "Media"
Texture
Download link for full version 6.0.2 (Jarvis) 3/6/2016
https://mega.nz/#!DRh0WAiQ!xtORQsoHiRoAt...0ChUqQ4V1A
Download link for full version 6.0.1 (Jarvis)
https://mega.nz/#!Cc41iT7b!TAvoAt1g7_VSRAhh2T_iEzISDFm6JMW-3jNZnR7k63E
watch gallery
New moded version V6 with new things add in link....GitHub verion is updated.
watch gallery
New version (all changes In Mod version) 16.2.2016
-new look for widget (poster with case,clearart,lclearlogo,discart,panel zoom,landscape,fanart...)
-images for cast is visible in Home
-set new stuff for widget in skin setting
-new galerry content in home window
-new view Modern view
-new view Coverflow and back
-new view middle list
-add view Midl list view from Scott967 github
-new way to set widget (skin.helper script)
-new way to set view
-new way for forced view in all content (skin.helper script)
-new low list EPG
-new look of PVR
-new view for channel PVR lite
-new view for channel AeonNox Maniac view
-new widget in list (content over 50 pcs)
-VNode now have widget (great for addon)
-new background source (skin.helper script)
-all new dialog for PVR,Album,Movies extended script
-all content have support to see cast for widget in home menu
-trailer, pvr radio & channel and director content have images
-add support for australian MPAA ( rjsachse )
-new view for recordings ( rjsachse )
-Add Media Portal PVR Recording Dialog ( rjsachse )
-Add Buffer progress bar in full screen
-Add menu for Tv Guide Live
-Add button for one click changer for widget on Home.(like AeonMQ5)
-Add function for letter "m" in all view.With "m" set focus to top menu button
-Flags ,Art and Info for movie set can see in widget and library (skin.helper script)
-Add Infos for Widget Set
-Add in weather widget, Maps from sattelite
-Add Images for content menu
-Add Animated poster and FanArt
-Info for Music in Visualisation can hide
-Included Images from resources.Script (studio,Weather,RecordLabel,...)
-Fixed button for Openelec,MusicPlayer,search widget....
-menu more new stuff....
Full credits go for creation of Modern case go to @Repoman ...mine idea ,but photoshop creation is his hands masterpeace
Thank you angelinas
Can you just post that view for us, regular mq6 users use?
Love that 'Gallery' view, good job Angelinas Nod
Thanks for the mod
Perfect
@ikaruz find errors all fixed,
Open for message,now you closed.
ikaruz Wrote:1. in extra menu the first line of widgets menu is behind the vertical menu
Dont understand,can show me a picture
ikaruz Wrote:2. cdart.png ist display twice ( there is a second one behind ) in main menu leftbutton
3. there are are 5 or 6 >> in the skin code . is this normal or are this errors?
Solved cd,>> is wrong typo error....
ikaruz Wrote:4. Movie set mod, the codec line in the button is to mutch i think.
there come 1 line vor every movie in the set.
Set is more then one movie ,I put info for four (4) moves in set
solved
ikaruz Wrote:5. there isnt no aspectratio png in movieset
FIxed
ikaruz Wrote:6. in seasen the 2. studio logo i think its dont need or ? one at button and now one at the same site at the top
remove for all ,stay for movies ...both,Ilike that
ikaruz Wrote:7. here the custom menu 1 and dont work. have i made a mistake ?
Missing some variable solved
ikaruz Wrote:can you tellme what code is for the casecodec png in the horizontal main menu because i have this in casecodec folder
you can see here how i made it http://forum.kodi.tv/showthread.php?tid=...pid2158313
hope you can help me
Casecodec is alredy in xbt (Gold).....If you want to change create new folder in flags with name "silvercodec".Open all your xml in notpad+ and change this
flags/videocodec
in
flags/silvercodec
sorry for my bad english too
TNX for reporting...keep finding more Smile
Can this mod be put on github so fixes and other mods and be easy downloaded and not have to re-download the whole skin again. I've done a another recorded tv view and added skin helper duration to show hours and minutes instead of just total minutes.
I see there is a issue with top tool bar with recorded tv and pvr images are not there either.
I have added pvr images for recorded tv. Too
I like the new epg view but is some issues with top bar again.
Thanks again.
I see a very strange situation
Playing a Video and with pause button i could see at the upper left side of the screen the movie's title
But in some of them , the title does nor appear.
WHY? Anything wrong?
Also i like very much when i am at the View options / Change View , the Full Screen Icon and down below the Dialogue Seekbar
But as i wrote before , in the movies where the title does not appear , also in the same movies i can not see the features of the Full Screen Icon and the Dialogue Seekbar
Is there any solution?
Mostly it happens in the old production movies , but also happens in very few new productions
Thanks for your attention
angelinas really like this mod, is it possibly to get mod (gallery extra) when movies and tvshows are marked instead in extras. So my new addes movies and tvshows are on the postersSmile
(2015-11-15, 12:27)Rjsachse Wrote: [ -> ]Can this mod be put on github so fixes and other mods and be easy downloaded and not have to re-download the whole skin again. I've done a another recorded tv view and added skin helper duration to show hours and minutes instead of just total minutes.
Thanks again.
Try This !
I just tested some things,lets make this mod like other and more powerful and usful
https://github.com/Angelinas1/skin.aeonmq6.mod
Never use github as a "master",if I need help iI'll ask from you.Try to create pullRequest...le it see how work Smile
(2015-11-15, 17:22)Bkam Wrote: [ -> ]angelinas really like this mod, is it possibly to get mod (gallery extra) when movies and tvshows are marked instead in extras. So my new addes movies and tvshows are on the postersSmile
I will try to add list like flexible widget to chose info for 7 of 9 poster.For now all 9 have fixed content.
2 poster have info for tvShow that is litle complicated to change.....in the future
Poster with content RottenTomatoe Fanart is from script.helper (From Fanart.tv),fanart in extra.Script is blank.
its ok to have fixed content , insted of a widget i want to use it like a widget and se my recented added movies / tvshows
Like in Aeonnox background "Live DVD Cases"
(2015-11-15, 19:13)Bkam Wrote: [ -> ]its ok to have fixed content , insted of a widget i want to use it like a widget and se my recented added movies / tvshows
3 widget have content from service.library.data.provider in Extra Gallery
-reacent Movie (from left no.4)
-random Movies (from right no.3)
-reacent Movies & Episodes (from right no.1)
If you mean to create one content to populate all nine poster,dont like that.Poster will be fixed at one info...for that use regular widget.
Script helper have some beckground wall I try in PVR...Maybe some moding with this and you have Reacent Movie in background.
Can somebody try to download new github and try to confirm is this working...some changes.
