2015-11-19, 23:05
I can't build the latest version. This are the last lines of the log. If you need more, pls let me know.
and
I have downloaded the latest version of the build script before I tried to compile it.
PS: Why does it say "* BUILD SUCCESSFUL!"?
Hunk #1 succeeded at 261 with fuzz 1 (offset 9 lines).
[1;33mFIXCONFIG[0m build.OpenELEC-WeTek_Play.arm-7.0-devel/connman-1.30/
[1;33mBUILD[0m libffi [1;37m(target)[0m
[1;35mAUTORECONF[0m libffi
autoreconf: Entering directory `build.OpenELEC-WeTek_Play.arm-7.0-devel/libffi-3.2.1'
autoreconf: configure.ac: not using Gettext
autoreconf: configure.ac: not using aclocal
autoreconf: configure.ac: tracing
autoreconf: configure.ac: not using Libtool
autoreconf: running: /media/OE/projects/OpenELEC.tv/build.OpenELEC-WeTek_Play.arm-7.0-devel/toolchain/bin/autoconf --include=/media/OE/projects/OpenELEC.tv/build.OpenELEC-WeTek_Play.arm-7.0-devel/toolchain/armv7a-openelec-linux-gnueabi/sysroot/usr/share/aclocal --force
configure.ac:19: error: possibly undefined macro: AM_INIT_AUTOMAKE
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
configure.ac:39: error: possibly undefined macro: AM_PROG_AS
configure.ac:40: error: possibly undefined macro: AM_PROG_CC_C_O
configure.ac:41: error: possibly undefined macro: AC_PROG_LIBTOOL
configure.ac:64: error: possibly undefined macro: AM_MAINTAINER_MODE
configure.ac:68: error: possibly undefined macro: AC_FUNC_MMAP_BLACKLIST
configure.ac:71: error: possibly undefined macro: AM_CONDITIONAL
autoreconf: /media/OE/projects/OpenELEC.tv/build.OpenELEC-WeTek_Play.arm-7.0-devel/toolchain/bin/autoconf failed with exit status: 1
make: *** [release] Fehler 1
## BUILD FINISHED: Do 19. Nov 21:58:42 CET 2015
## BUILD DURATION: 110 seconds
00h00m00s: Git branch is: master
00h00m00s: Kodi branch is: master
00h00m00s: OE_KODI_VER is:
00h00m00s: Profile : wetek
00h00m00s: Debug enabled : No
00h00m00s: Proj/Arch/Vers: WeTek_Play/arm/devel
00h00m00s: Build Log : /media/OE/projects/log.job1
00h00m00s: Build code is : 151119
00h00m00s:
00h01m50s: 40.53% complete [wetek: log.job1] * BUILD SUCCESSFUL!
ERROR: No new sytem image found, check log!
Build failure: wetek (WeTek_Play.arm-devel)
