Full Version: Mismatch
Good morning,
I apologize if I ask something that has already been talked about but have not found anything on the forum.
I wanted to know if there is a system to automatically change the channel names from the m3u file on IPTV Simple Client to match those of the xml file Rytec.
Thank you.
i think you have to do it manually, you can use Kodi M3U IPTV Editor the one i used to tune my list.
Peppe
Thx for your replay. I have read somewhere that it's possible use a "script" to do automatically, but i don't know what is a script Tongue
I was hoping someone here in the forum know how to do, or in some other way.
The problem with doing it manually is that the list will change from week to week, and then every time should be amended.
Thank you.
