2015-11-17, 02:53
Wondering if anyone can help.
The Stalker PVR Client that is included in Kodi is behaving strangely.
With the Jarvis beta 1 build, on my iPad Air 2, I am able to:
1. Enable Stalker PVR Client
2. Perform the setup
3. Enable Live TV
4. It works perfectly
However when I shut down Kodi and then relaunch Kodi, it crashes hard and I am unable to start Kodi. I then connect it to my computer running Xcode and all is fine again. I can shut it down and run via Xcode no problem. But if I disconnect it stops working. Now while I am connected I will disable the PVR Client and shut down Kodi, I will then disconnect from my computer/Xcode and Kodi will launch no problem and I am able to perform the above steps and it works fine until I shutdown Kodi and try to relaunch Kodi again.
Here is a link to the crash report:
Kodi Crash when PVR is enable after subsequent Launch
@Memphiz : I was thinking it had something to do with this: dylibs in iOS9 but it doesn't make sense that it works when I initially set up the Stalker PVR client and then only when i shutdown kodi and try to restart does it continuously crash. I can dig and try to fix but was looking for some pointers on where to look. I will investigate the dylib for the stalker PVR client and see if I can figure anything out, but any help would be appreciated... or some direction...
3. Enable Live TV
