2008-02-23, 18:38
2008-05-25, 21:58
i have a script before every location url
ex.
details.1.html
how can i force scraper to skip this
smuto
ex.
details.1.html
smuto
2008-05-26, 19:06
2008-05-26, 22:46
spoof is for setting the referer. it probably does the trick indeed. sorry for the late response
2008-06-10, 15:21
maybe it's not xbmc problem, but maybe u can help
Recently in movie info from filmweb scraper, accented characters are show as a entities
ex.
latin small letter o with acute
ó -> ó
is the way to fix this
smuto
ex.
ó -> ó
smuto
2008-06-10, 15:39
hmm, it should convert those tags when you load the xml?
if not, make sure cleaning is performed on the field. latter would remove them though
2008-06-11, 21:35
with or without "noclean" i still have this same
ex
xbmc shows
który -> ktoacute;ry
in .xml from scrap.exe
który -> który
realy don't know what to do
i need to update SVN (small url function link fix)
but for now,this one is good for testing entitie
filmweb.xml_test
good for test is "Kingdom of the Crystal Skull"
tag title is OK
tags outline & plot are wrong
ex
xbmc shows
który -> który
filmweb.xml_test
tag title is OK
2008-07-08, 21:51
for myself i edit source file HTMLUtil.cpp
edited HTMLUtil.cpp
it's working, but i hope u help to fix this for all polish users
smuto
edited HTMLUtil.cpp
strReturn.Replace("–", "-;");
strReturn.Replace("ó", "ó");
smuto
2008-09-14, 21:23
i add fanart to filmweb scraper
i use polish wikipedia to migration from filmweb.id to imdb.id
we still have problem with entities, hope spiff find time to help us
u can test new scraper from here
filmweb.xml_test_scraper
smuto
smuto
2008-09-18, 00:28
hi.
i see nothing wrong, nor any other way to handle this so i just commited your replaces along with the new scraper. please use trac in the future
spiff
spiff
2008-09-24, 18:22
@smuto: There are some problems with titles that start with numbers eg. "1410" or "27 dresses" - numbers are cut off from them. Fanart support is really great.
I hope that xbmc compilation with edited HTMLutil.cpp will be ready soon. At this moment you could put your compiled xbmc default.xbe at smuto.w.interia.pl (would be great for me, because i want to rescan my movie library and polish plots with no entity problems is something I look for...)
2008-10-01, 19:47
Eventhough entities has been fixed with changeset 15625 it seems that "oacute problem" still exists (I checked filmweb scraper on xbmc compilations 15640 and 15728). Smuto - do you agree with me?
2008-10-03, 19:09
@haken - u just need to update scraper
filmweb.xml
@spiff
this mean i should add all entities to replaces
next in my queue are
smuto
filmweb.xml
@spiff
Quote:i see nothing wrong, nor any other way to handle this so i just commited your replacesbut this is not a good idea - "oacute" & "ndash" are most popular
strReturn.Replace(" ", "");
strReturn.Replace("’", "'");
2008-10-07, 09:04
i don't know why, but sometimes wikipedia search don't work
i change the way of scraping the link after search - please test
filmweb.xml
is the way to show in skin custom label?
something like this i need for testing
ListItem.IMDbID or ListItem.FilmwebID
smuto
filmweb.xml
smuto
2008-11-01, 08:50
@smuto: I think that there are some changes in filmweb.pl website - descriptions cannot be scraped and high-res posters also. I looked inside the scraper, but it is to complicated for me
Update: Scraper is ok! It was something else - now everything works perfect. I was surprised because each time earlier scraper worked or didn't work at all... Sorry!
