This is my first "release" of the filmweb (polish movie database side) scraper.
The mainfeatures work, but there are one big problem:
-xbmc don't show the polish chars at all
Filmweb - Scraper
cheers smuto
i test this scraper after spiff fix
fixed: various encoding related stuff in scraper code. should fix ofdb.
this fix give me correct writing to database, but strings are not readable in GUI
Revision: 7829
http://svn.sourceforge.net/xbmc/?rev=7829&view=rev
Author: spiff_
Date: 2007-02-13 16:16:50 -0800 (Tue, 13 Feb 2007)
Log Message:
fixed: if scraper says it returns utf8 formatted xml, obey.
you should have a look at the actors. and don't use tag line, use <originaltitle>
- i fix actar tag (whitespaces bug)
- i add <originaltitle> tag
Filmweb-scraper
added to svn with some small modifications due to changes to buffer cleanings. also renamed it to filmweb.pl.
cheers
spiff
Rating tag issue
e.g
from scraper 8,73 (comma) are shows as 8.0 (dot) in GUI
one more
"votes" should be localized.
smuto
yes, it needs to conform to standard floating point numbers, i.e. use a . and not a ,
localization is added.
done
i hope this is the last update
spiff - i want to thank you very much.
please update the scraper to reflect the <nfourl> changes
scraper in this link
filmweb.xml
is only for tests to forum users (i need more testers)
last good working one i will always upload to SVN as a patche
smuto
oh rite i did commit the last one - will stick to the sf ones from now on
Hi! (siema)
I have many movies and many nfo files associated with them with urls to imdb and filmweb entries inside. Filmweb scraper works well olny for urls starting with
http://www.filmweb.pl/Film,id...
Doesn't work for urls like
http://frantic.filmweb.pl/ and I have them plenty...
Please update the regexp, probably the matching one in NfoUrl so that filmweb url would be correctly recognized in the nfo...
Regards,
dowiew
