Full Version: Problem with hardware decoding on XVID file
Hi guys,
I have a problem when I try to play some XVID files with hardware acceleration enabled. I must turn it off if I want to watch those XVID videos.
And that's a problem because I usually play a lot of hevc files that require this acceleration.
Here's a screenshot of the screen:
Quote:Complete name : Z:\TV\My Wife and Kids\Season 4\S04E09.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 175 Mio
Duration : 20mn 36s
Overall bit rate : 1 189 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2439/release)
Writing library : VirtualDubMod build 2439/release
Vidéo
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : 2
Format settings, QPel : Non
Format settings, GMC : Pas de warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 20mn 36s
Bit rate : 1 056 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 25,000 Im/s
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressif
Compression mode : Avec perte
Bits/(Pixel*Frame) : 0.137
Stream size : 156 Mio (89%)
Writing library : XviD 0.0.09 (UTC 2003-03-25)
I run an Android with AMLOGIC S812 chipset and 1gig of ram. Any thoughts?
What version are you using? SD mpeg4 /xvid /divx playback on Android uses systematically software since a while, now, due to this kind of incompatibilities...
