Full Version: Autoexec.py editor def!! HANDY?
Hi all,
I just wrote this code for my ResumeX script and thought this might come in handy for people that add functions into their scripts that can enable/disable scripts run on startup.
def editauto(self):
                test = xbmc.getInfoLabel("system.profilename")
                test = str(test)
                print str(test)
                if test != "Master user":
                        if os.access("P:\\scripts\\", os.F_OK)==0:
                                os.mkdir("P:\\scripts\\")
                        autoexecfile = "P:\\scripts\\autoexec.py"
                else:
                        if os.access("Q:\\UserData\\scripts\\", os.F_OK)==0:
                                os.mkdir("Q:\\UserData\\scripts\\")
                        autoexecfile = "Q:\\UserData\\scripts\\autoexec.py"
                if os.path.exists(autoexecfile):
                        fh = open(autoexecfile)
                        count = 0
                        lines = []
                        for line in fh.readlines():
                             theLine = line.strip()
                             if theLine.startswith("xbmc.executescript('Q:\scripts\ResumeX\lib\engine.py')"):
                                     return
                             lines.append(str(line))
                             count = count + 1
                        fh.close()
                        lines.append("xbmc.executescript('Q:\scripts\ResumeX\lib\engine.py')\n")
                        count = count + 1
                        f = open(autoexecfile, "wb")
                        for i in range (0 , count):
                                f.write(lines[i])
                        f.close()
                        return
                else:
                        f.write("import xbmc\n")
                        f.write("xbmc.executescript('Q:\scripts\ResumeX\lib\engine.py')")
                        f.close()
                        return
Of course, it needs to be edited to the your particular script, but apart from that, is should work good. It has a feature so it doesnt add the line twice etc, so this can be run everytime the script is run via autoexec.py and NO double ups will occur. Also, its profile friendly! :-D
Let me know your thoughts.
Cheers
Stanley87
def addauto(self):
            test = str(test)
            else:
                    count = 0
                    lines = []
                                 return
                         count = count + 1
                    fh.close()
                    count = count + 1
                    f = open(autoexecfile, "w")
                            f.write(lines[i])
                    f.close()
                    return
            else:
                    f.close()
                    return
    def removeauto(self):
            test = str(test)
                            return
            else:
                            return
                    count = 0
                    lines = []
                                 pass
                         else:
                         count = count + 1
                    fh.close()
                    for i in range (0 , count-1):
                            f.write(lines[i])
                    f.close()
                    return
            return
So there is a def for adding to/creating an autoexec.py and also a def for removing the scripts execute line from autoexec.py
So, this code won't CHANGE any previous autoexec.py allready in place, but instead, add to it. Same when removing the script. Any other script that is run via the autoexec.py will stay in tact :-D
See this in action at the link below:
http://xbmc-scripting.googlecode.com/svn...default.py
Pretty cool. If you want to make it more generic you could pass in the script pass as an argument instead.
Also there are some places that can be shorter... like instead of count use len(lines)... also there is a f.writelines(lines)
If you don't mind going a bit more advanced your central read loop can be replaced with
lines = [ line for line in fh if not line.strip().startswith(script) ]
(the in operator here is an iterator like readline() )
heres abit better version:
def addauto(self):
                    lines = []
                         if theLine.startswith(Script):
                                 return
                    fh.close()
                    lines.append(Script+"\n")
                    f.writelines(lines)
                    f.close()
                    return
            else:
                    f.write(Script)
                    f.close()
                    return
                    return
                    lines = [ line for line in fh if not line.strip().startswith(Script) ]
                    fh.close()
                    f.writelines(lines)
                    f.close()
                    return
            return
Where Script is a global variable in the form:
Script = "xbmc.executescript('Q:\\scripts\\ResumeX\\engine.py')"
Actually, probably safer to do:
Script = "xbmc.executescript('Q:\\\\scripts\\\\ResumeX\\\\engine.py')"
