Full Version: Internet connection
Hi Guys and a very good morning to one and all.
I have an Android media player, running kodi 15.2.
I'm having a bit of connectivity issues ie connecting to the internet. My media player is connected to the router via Ethernet.
Just as an aside, I have no other connectivity issues from a phone or tablet. I'm only using Kodi for YouTube and to Check the weather. The response is either slow, or no connection at all.
Is there some place I can go, to enter any specific things within kodi?
I had a look at settings, under webserver it's the following:
Allow remote control via http: ticked
Port:8080
Web interface: default webinterface
Then under system
User proxy server: ticked
Proxy type: http
Server: blank
Port: 8080
Username and password also blank
Anything I'm missing here?
Thanks in advance
Do not "tick" proxy server if you're not using one.
(2015-11-22, 14:56)Koying Wrote: [ -> ]Do not "tick" proxy server if you're not using one.
Thanks I'll get that unticked, and see what happens.
Cheers
