2016-11-30, 04:37
2016-12-02, 06:42
Updated everything... Kodi 17 beta 6 and installed master refocus branch via zip as of today. Still seems to be missing the show names in the watchlist:
What am I missing? Thanks!
watch gallery
(2016-11-12, 10:40)Jeroen Wrote: [ -> ](2016-09-03, 20:32)breezin Wrote: [ -> ]Just updated from an old version. Everything seems to be working well and my watchlist info seems to have propagated as well.
However, the watch list no longer give the show name. Just the episode title, season #, episode #, date. I swear this used to also give me the show's name as well. So if I want to watch the next episode of Dark Matter is a pain to find it quickly. Is there a setting somewhere to turn on show names for the watch list?
This is fixed on Git.
2016-12-02, 07:49
(2016-12-02, 06:42)breezin Wrote: [ -> ]Updated everything... Kodi 17 beta 6 and installed master refocus branch via zip as of today. Still seems to be missing the show names in the watchlist:
Removing and re-adding the watchlist entry in your home menu should fix that.
2016-12-02, 21:28
Just did a reset all skin settings... all is working great now! Thanks!
Love this skin!
Love this skin!
(2016-12-02, 07:49)Jeroen Wrote: [ -> ](2016-12-02, 06:42)breezin Wrote: [ -> ]Updated everything... Kodi 17 beta 6 and installed master refocus branch via zip as of today. Still seems to be missing the show names in the watchlist:
2016-12-03, 11:43
Is there any way to show an HDR Logo for movies that support 10-bit? I can't distinct which movies are HDR and which not
2016-12-05, 18:23
(2016-12-03, 11:43)c0heed Wrote: [ -> ]Is there any way to show an HDR Logo for movies that support 10-bit? I can't distinct which movies are HDR and which not
not to my knowledge, i don't think Kodi has anything built in for it. could be wrong though
2016-12-19, 21:37
Is there anyway when viewing files and you select viewtype in Movies Tv..etc IElide that it becomes system default or like Titan skin you have a forced view function in settings for Movie's , Box sets etc....
Thanks for the help.
argos400
argos400
2017-01-01, 20:52
Kodi 17 RC1 I noticed an error with the skin while displaying video:
And this issue http://forum.kodi.tv/showthread.php?tid=...pid2357197 is showing up again.
Thanks for your work!
2017-01-07, 17:22
I'm running Kodi 17.0 RC2 latest build on my Windows 7 machine.
Wanted to test your skin so downloaded xbmc.repo.jeroen-1.0.3.zip from https://github.com/jeroenpardon/xbmc.rep...n/releases but there is error message when trying to install that skin: "The dependency on xbmc.gui version 5.3.0 could not be satisfied.
2017-01-21, 16:07
(2017-01-07, 17:22)rafikW Wrote: [ -> ]I'm running Kodi 17.0 RC2 latest build on my Windows 7 machine.
That's a very old version. At the moment I am not using the repo add-on actively. Please use a snapshot from Got or wait for the. official Kodi 17 release.
2017-01-21, 16:21
(2017-01-01, 20:52)McYoshi Wrote: [ -> ]Kodi 17 RC1 I noticed an error with the skin while displaying video:Fixed on Git, cheers
Quote:And this issue http://forum.kodi.tv/showthread.php?tid=...pid2357197 is showing up again.Will investigate, thx
2017-01-21, 16:22
(2016-12-19, 21:37)argos400 Wrote: [ -> ]Is there anyway when viewing files and you select viewtype in Movies Tv..etc IElide that it becomes system default or like Titan skin you have a forced view function in settings for Movie's , Box sets etc....
argos400
It should remember the last chosen view. No forced views and no plans to, sorry.
2017-01-23, 14:25
(2017-01-21, 16:22)Jeroen Wrote: [ -> ]It should.(2016-12-19, 21:37)argos400 Wrote: [ -> ]Is there anyway when viewing files and you select viewtype in Movies Tv..etc IElide that it becomes system default or like Titan skin you have a forced view function in settings for Movie's , Box sets etc....
argos400
It does have a habit of forgetting every now and then.
That said, mine hasn't done that in a long time.
2017-01-24, 12:42
If I want to upgrade to Krypton, is there a stable version of Refocus on Git?
2017-01-24, 15:35
(2017-01-24, 12:42)lstar337 Wrote: [ -> ]If I want to upgrade to Krypton, is there a stable version of Refocus on Git?
It's stable but not completely 'finished'. For instance unwatched indicators and some views not working correctly.
