2016-01-27, 01:11
2016-01-27, 11:17
(2016-01-26, 20:21)thewarm Wrote: [ -> ]I also found that by (un)installing the extended info script open dialog add-on I can get extended info to work normally.Still not working here. Can you explain in more detail?
2016-01-27, 12:29
(2016-01-27, 11:17)lstar337 Wrote: [ -> ]Make sure you install context.extendedinfo.dialog. Then when a movie or TV show is in focus, hit "C" to get to the context menu. You will see extended info at the bottom. It works normally.(2016-01-26, 20:21)thewarm Wrote: [ -> ]I also found that by (un)installing the extended info script open dialog add-on I can get extended info to work normally.Still not working here. Can you explain in more detail?
I downloaded Mimic to see how Extended Info was handled. In Mimic when you look at a cast member, you hit the down arrow to launch the add-on. More intuitive.
2016-01-28, 20:32
I've been using this 'preview' for several days now... love it.
I noticed when playing FLAC music files, the progress slider doesn't work. It just sits there. It does work for video files.
2016-01-29, 03:08
It doesn't work for all music files. It's a preview... I miss more things but like the new stuff. Cant decide if i want to go back to v15 or stick with v16.
2016-02-02, 02:25
I came across an alignment error in one of the system settings screens. This is still on ReFocus 2.0 for Isengard, but I figured this was the most appropriate place to post.
Also, I'm not sure if this is a bug or intentional, but the cast information for a movie/TV show only lists the actor and not their character. I believe my .nfo files are correct. I know the info screen is getting a major rewrite so this may be a moot point.
2016-02-02, 11:04
The alignment in system information has been like that for a while.
I doubt the other issues will be looked at because I think ReFocus 2.0 has been put to bed.
2016-02-02, 17:18
(2016-02-02, 11:04)lstar337 Wrote: [ -> ]The alignment in system information has been like that for a while.
Does the cast view behave the same way for you? I'd like to confirm that it's not just a problem on my end.
2016-02-02, 19:00
(2016-02-02, 17:18)ZwartePiet Wrote: [ -> ]I can't say for sure as I only use Jarvis and this preview, but as far as I recall I have never seen character names listed.(2016-02-02, 11:04)lstar337 Wrote: [ -> ]The alignment in system information has been like that for a while.
Somebody else can probably confirm that in the 2.0 thread.
2016-02-11, 21:27
... no movement in the reFocus 3.0 git since dec 20, 2015...
Is there still hope of a resurrection for us reFocus fans..?
2016-02-11, 21:33
For sure. Jeroen is probably busy right now.
2016-02-12, 21:49
He probably bought an Apple TV just kidding, although I have to say it looks amazing. But now back to topic. Sorry about that
2016-02-13, 13:46
(2016-02-11, 21:27)Raitsa Wrote: [ -> ]... no movement in the reFocus 3.0 git since dec 20, 2015...
There is. Sorry for the recent lack of updates but this is a one man operation and all. reFocus doesn't pay the bills so I still have a day job And there's too little free time for too many interests Hoping to do some coding this Sunday but a lot of work hasn't been pushed to Git yet as all it would do is break stuff.
2016-02-16, 13:07
(2016-02-13, 13:46)Jeroen Wrote: [ -> ]There is. Sorry for the recent lack of updates but this is a one man operation and all. reFocus doesn't pay the bills so I still have a day job And there's too little free time for too many interests Hoping to do some coding this Sunday but a lot of work hasn't been pushed to Git yet as all it would do is break stuff.Thanks for the heads up Jeroen, and good to see you posting again.
2016-02-16, 13:35
Its a very good day here in Finland: the sun is shining and elsewhere Jeroen is back with reFocus 3.0.
Good to see you back Jeroen; we all here need to contact your boss and tell him to give you a well deserved raise.
