Full Version: Create your own youtube addon with the Youtube Addon Template
Create your own youtube addon by using the youtube addon template - you just need a text editor (notepad++ or similar program)
- No coding is necessary
- To add - you just need to add/replace the urls you wish to use with either the user id or the channel id -
- Adding icons is also very easy - just copy image url then add/replace where stated in the video
- Everything is demonstrated in the video
- https://youtu.be/aPEBluurRoY
download link - https://www.dropbox.com/s/1uxr2o2u4j8faz...e.zip?dl=0
Why is there a need to join your Facebook group to gain access to the add-on.
it is.
please make your code publicly accessible without the need to signup.
(2015-11-22, 16:39)ronie Wrote: [ -> ]it is.
hopefully that has sorted it
Can u make a video to show how to make this youtube addon?
The video says its not available
