Hi
I just tried Kodi 16 Jarvis and the PVR addon won't load correctly saying "No PVR addon enabled" despite my VNSI addon is actually enabled.
In the log it says incompatible version (see below) but in the Kodi unstable PPA the version 1.10.10-1~trusty is still the newest !?
18:51:44 T:139818835113728 NOTICE: PVRManager - starting up
18:51:44 T:139818407282432 ERROR: PVR - Add-on 'VDR VNSI Client' is using an incompatible API version. XBMC minimum API version = '4.1.0', add-on API version '1.9.6'
18:51:44 T:139818407282432 WARNING: UpdateAndInitialiseClients - failed to create add-on VDR VNSI Client, status = 6
18:51:44 T:139818407282432 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on VDR VNSI Client, disabling it
Is there a compatible Jarvis version for VNSI?
The Jarvis compatible addons are in the nightly ppa. I'll ping the packager.
ok the I will just use that one, thx
Ok I am having the same issues on Beta4. i will post a log later tonight when I got the time.
I already reseted the PVR settings and DB. PLugin is 1.11.8-4
Ok here we go:
Looks like a GUI incompatibility:
22:36:03 T:140553509385984 NOTICE: PVRManager - starting up
22:36:03 T:140552435644160 DEBUG: Thread PVRManager start, auto delete: false
22:36:03 T:140553249343232 DEBUG: Thread PVRClient start, auto delete: false
22:36:03 T:140553249343232 DEBUG: RegisterClient - registering add-on 'VDR VNSI Client'
22:36:03 T:140553249343232 DEBUG: Previous line repeats 1 times.
22:36:03 T:140553249343232 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
22:36:03 T:140553249343232 DEBUG: ADDON: Dll Initializing - VDR VNSI Client
22:36:03 T:140553249343232 DEBUG: SECTION:LoadDLL(/usr/lib/kodi/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.so.1.11.8)
22:36:03 T:140553249343232 DEBUG: Loading: /usr/lib/kodi/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.so.1.11.8
22:36:03 T:140553249343232 ERROR: PVR - Add-on 'VDR VNSI Client' is using an incompatible GUI API version. XBMC minimum GUI API version = '5.10.0', add-on GUI API version '5.8.0'
22:36:03 T:140553249343232 WARNING: UpdateAndInitialiseClients - failed to create add-on VDR VNSI Client, status = 6
22:36:03 T:140553249343232 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on VDR VNSI Client, disabling it
Full debug log:
http://pastebin.com/wT3szDHd
What I did:
1) disabled LiveTV
2) upgrade to Beta4
3) reboot
4) check VNSI plugin is enabled
5) enabled LiveTV -> Error message
any new when the vnsi addon gets updated to xbmc.pvr version 4.2.0 supporting latest git of kodi?
(2016-01-23, 18:18)a_user Wrote: [ -> ]any new when the vnsi addon gets updated to xbmc.pvr version 4.2.0 supporting latest git of kodi?
I did this right after I pushed the api change.
(2016-01-23, 21:02)FernetMenta Wrote: [ -> ] (2016-01-23, 18:18)a_user Wrote: [ -> ]any new when the vnsi addon gets updated to xbmc.pvr version 4.2.0 supporting latest git of kodi?
strange, cause the addon.xml.in on git still says depending on 4.1.0 and using this addon (either compiled from git or with kodi and pvr add on from the unstable ppa) fails loading the addon saying that it can't load that addon because of outdated api version. kodi needs 4.2.0 but addon has only 4.1.0.
i see, there just came a new commit within the last hours fixing this.
