11:24:22 T:1299138784 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:24:22 T:1299138784 NOTICE: -----------------------------------------------------------------------
11:24:22 T:1299138784 NOTICE: Starting Kodi (15.2 Git:2015-10-19-02e7013). Platform: Android ARM 32-bit
11:24:22 T:1299138784 NOTICE: Using Release Kodi x32 build
11:24:22 T:1299138784 NOTICE: Kodi compiled Oct 19 2015 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
11:24:22 T:1299138784 NOTICE: Running on Hisilicon COMBO2 with Android 4.4.2 API level 19, kernel: Linux ARM 32-bit version 3.10.0_s40
11:24:22 T:1299138784 NOTICE: FFmpeg version: 2.6.4-kodi-2.6.4-Isengard
11:24:22 T:1299138784 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
11:24:22 T:1299138784 NOTICE: Product: Hi3796MV100_fl_combo2, Device: Hi3796MV100, Board: bigfish - Manufacturer: Hisilicon, Brand: Spark2, Model: COMBO2, Hardware: bigfish
11:24:22 T:1299138784 NOTICE: External storage path = /storage/emulated/0; status = ok
11:24:22 T:1299138784 NOTICE: ARM Features: Neon enabled
11:24:22 T:1299138784 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
11:24:22 T:1299138784 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
11:24:22 T:1299138784 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
11:24:22 T:1299138784 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
11:24:22 T:1299138784 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
11:24:22 T:1299138784 NOTICE: The executable running is: /system/bin/app_process
11:24:22 T:1299138784 NOTICE: Local hostname: localhost
11:24:22 T:1299138784 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
11:24:22 T:1299138784 NOTICE: load settings...
11:24:23 T:1299138784 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
11:24:23 T:1299138784 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
11:24:23 T:1299138784 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
11:24:23 T:1299138784 DEBUG: AESinkAUDIOTRACK - 44100 supported
11:24:23 T:1299138784 DEBUG: AESinkAUDIOTRACK - 48000 supported
11:24:23 T:1299138784 NOTICE: Found 1 Lists of Devices
11:24:23 T:1299138784 NOTICE: Enumerated AUDIOTRACK devices:
11:24:23 T:1299138784 NOTICE: Device 1
11:24:23 T:1299138784 NOTICE: m_deviceName : AudioTrack
11:24:23 T:1299138784 NOTICE: m_displayName : android
11:24:23 T:1299138784 NOTICE: m_displayNameExtra: audiotrack
11:24:23 T:1299138784 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:24:23 T:1299138784 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
11:24:23 T:1299138784 NOTICE: m_sampleRates : 44100,48000
11:24:23 T:1299138784 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
11:24:23 T:1299138784 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:24:23 T:1299138784 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:24:23 T:1299138784 NOTICE: Default DVD Player: dvdplayer
11:24:23 T:1299138784 NOTICE: Default Video Player: dvdplayer
11:24:23 T:1299138784 NOTICE: Default Audio Player: paplayer
11:24:23 T:1299138784 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:24:23 T:1299138784 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:24:23 T:1299138784 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
11:24:23 T:1299138784 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:24:23 T:1299138784 NOTICE: Loaded playercorefactory configuration
11:24:23 T:1299138784 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:24:23 T:1299138784 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:24:23 T:1303423856 NOTICE: Thread ActiveAE start, auto delete: false
11:24:23 T:1303238040 NOTICE: Thread AESink start, auto delete: false
11:24:23 T:1299138784 NOTICE: Running database version Addons19
11:24:23 T:1299138784 NOTICE: ADDONS: Using repository repository.xbmc.org
11:24:23 T:1299138784 NOTICE: ADDONS: Using repository repository.lambda
11:24:23 T:1299138784 NOTICE: ADDONS: Using repository repository.eldorado
11:24:23 T:1299138784 NOTICE: ADDONS: Using repository repository.xbmchub
11:24:23 T:1299138784 NOTICE: ADDONS: Using repository repository.metalkettle
11:24:23 T:1299138784 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
11:24:23 T:1299138784 NOTICE: Current resolution: 1280x720 @ 60.00 - Full Screen
11:24:23 T:1299138784 NOTICE: Previous line repeats 1 times.
11:24:23 T:1299138784 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000004 Hz
11:24:23 T:1299138784 NOTICE: Found (
[email protected]) at 16, setting to RES_DESKTOP at 16
11:24:23 T:1299138784 NOTICE: Checking resolution 16
11:24:23 T:1299138784 NOTICE: GL_VENDOR = ARM
11:24:23 T:1299138784 NOTICE: GL_RENDERER = Mali-450 MP
11:24:23 T:1299138784 NOTICE: GL_VERSION = OpenGL ES 2.0
11:24:23 T:1299138784 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:24:23 T:1299138784 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
11:24:23 T:1299138784 ERROR: Unable to load libcec.so, reason: dlopen failed: library "libmaliinstr.so" not found
11:24:23 T:1299138784 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
11:24:23 T:1315646736 NOTICE: Thread PeripBusUSB start, auto delete: false
11:24:23 T:1299138784 NOTICE: Running database version ViewModes6
11:24:23 T:1299138784 NOTICE: Running database version Textures13
11:24:23 T:1299138784 NOTICE: Running database version MyMusic52
11:24:23 T:1299138784 NOTICE: Running database version MyVideos93
11:24:23 T:1299138784 NOTICE: Running database version TV29
11:24:23 T:1299138784 NOTICE: Running database version Epg10
11:24:24 T:1299138784 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
11:24:24 T:1299138784 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
11:24:24 T:1299138784 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
11:24:24 T:1299138784 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:24:24 T:1331590808 NOTICE: Thread LanguageInvoker start, auto delete: false
11:24:24 T:1299138784 NOTICE: Previous line repeats 3 times.
11:24:24 T:1299138784 NOTICE: initialize done
11:24:24 T:1299138784 NOTICE: Running the application...
11:24:25 T:1341393064 NOTICE: Thread JobWorker start, auto delete: true
11:24:25 T:1331590808 NOTICE: -->Python Interpreter Initialized<--
11:24:25 T:1299138784 NOTICE: Previous line repeats 2 times.
11:24:25 T:1299138784 NOTICE: starting zeroconf publishing
11:24:25 T:1347022120 NOTICE: Thread ZerocconfEmbedded start, auto delete: false
11:24:25 T:1299138784 NOTICE: starting upnp client
11:24:25 T:1346702128 NOTICE: Thread JobWorker start, auto delete: true
11:24:25 T:1299138784 NOTICE: ES: Starting event server
11:24:25 T:1346063904 NOTICE: Thread EventServer start, auto delete: false
11:24:25 T:1346063904 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:24:25 T:1346063904 NOTICE: UDP: Listening on port 9777
11:24:25 T:1347037992 NOTICE: Thread TCPServer start, auto delete: false
11:24:25 T:1375682064 NOTICE: Thread AirPlayServer start, auto delete: false
11:24:25 T:1299138784 NOTICE: Current resolution: 1280x720 @ 60.00 - Full Screen
11:24:25 T:1299138784 NOTICE: GL_VENDOR = ARM
11:24:25 T:1299138784 NOTICE: GL_RENDERER = Mali-450 MP
11:24:25 T:1299138784 NOTICE: GL_VERSION = OpenGL ES 2.0
11:24:25 T:1299138784 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:24:25 T:1299138784 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
11:24:25 T:1376956400 NOTICE: Thread RSSReader start, auto delete: false
11:24:25 T:1333693064 NOTICE: -->Python Interpreter Initialized<--
11:24:26 T:1385444200 NOTICE: Thread JobWorker start, auto delete: true
11:24:26 T:1384815648 NOTICE: AxelProxy Downloader Starting - 127.0.0.1:45550
11:24:26 T:1384815648 NOTICE: Press CTL break to stop.....
11:24:26 T:1341198768 NOTICE: Thread LanguageInvoker start, auto delete: false
11:24:26 T:1333702664 NOTICE: StorageServer Module loaded RUN
11:24:26 T:1333702664 NOTICE: StorageClient-2.5.4 Starting server
11:24:26 T:1341198768 NOTICE: -->Python Interpreter Initialized<--
11:25:14 T:1369163928 NOTICE: Thread JobWorker start, auto delete: true
11:26:34 T:1299138784 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/media/Fonts/
11:26:34 T:1299138784 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting special://home/media/Fonts/
11:26:35 T:1299138784 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/media/Fonts/
11:26:35 T:1299138784 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting special://home/media/Fonts/
11:26:42 T:1299138784 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/media/Fonts/
11:26:42 T:1299138784 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting special://home/media/Fonts/
11:26:53 T:1360900600 NOTICE: Thread JobWorker start, auto delete: true
11:28:09 T:1360900600 NOTICE: Thread BackgroundLoader start, auto delete: false
11:28:13 T:1334746360 NOTICE: Thread JobWorker start, auto delete: true
11:28:13 T:1360900600 NOTICE: Thread BackgroundLoader start, auto delete: false
11:28:14 T:1360900600 NOTICE: Thread JobWorker start, auto delete: true
11:28:19 T:1456422584 NOTICE: Previous line repeats 2 times.
11:28:19 T:1456422584 NOTICE: Thread BackgroundLoader start, auto delete: false
11:28:32 T:1470789280 NOTICE: Thread FileCache start, auto delete: false
11:28:37 T:1360935376 NOTICE: Thread BackgroundLoader start, auto delete: false
11:32:32 T:1360900600 NOTICE: Thread LanguageInvoker start, auto delete: false
11:32:32 T:1360900600 NOTICE: -->Python Interpreter Initialized<--
11:32:36 T:1360900600 NOTICE: Kodi Log Uploader: started
11:32:36 T:1360900600 NOTICE: Kodi Log Uploader: settings: len(email)=21
11:32:36 T:1360900600 NOTICE: Kodi Log Uploader: settings: skip_oldlog=True
11:32:40 T:1360900600 NOTICE: Kodi Log Uploader: reading log...
