Full Version: Unable to install on Macbook Pro OSX 10.6.8
I've read the stickies, but my problem is I can't even install it.
I downloaded installer. I dragged Kodi into Apps from the dialog.
I hear the boing. I see it in Applications.
I click to run it and I get this message:
Process: Kodi [211]
Path: /Applications/Kodi.app/Contents/MacOS/Kodi
Identifier: org.xbmc.kodi
Version: Huh (Huh)
Code Type: X86-64 (Native)
Parent Process: launchd [89]
Date/Time: 2015-11-24 07:00:14.493 -0800
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 3239 sec
Crashes Since Last Report: 4
Per-App Crashes Since Last Report: 4
Anonymous UUID: 71B42A02-DC83-4745-9E06-90887D1CAEA1
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /usr/lib/libc++.1.dylib
Referenced from: /Applications/Kodi.app/Contents/MacOS/Kodi
Reason: image not found
Binary Images:
0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (Huh) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
Model: MacBookPro4,1, BootROM MBP41.00C1.B00, 2 processors, Intel Core 2 Duo, 2.6 GHz, 4 GB, SMC 1.27f3
Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 512 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8C), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST9500420AS, 465.76 GB
Parallel ATA Device: MATSHITADVD-R UJ-867
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1a100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x820f, 0x1a110000 / 3
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0230, 0x5d200000 / 3
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000 / 2
I think this is the relevant portion -
Dyld Error Message:
I've been doing a bit of research and this does not seem to be at all a simple fix.
It's like Apple neglected to install important library in their OSHuh
silvanet,
Just a thought... did you go to settings on your MAC, security & privacy, general tab, and changed the setting to allowed apps to be installed from anywhere?
Hope this helps
DarcMan
Current minimum osx version is 10.7 ... the last kodi version which supports 10.6.8 is kodi 14.1 iirc.
I kind of figured as much. Really hate Apple for their constant push to make you pay for ever more expensive models to be able to run software almost any other system can easily handle.
I'll try installing xbmc 14.1.
You know any Macbook Pro late 2007 or newer can run OS 10.11.1.
