Full Version: TV shows missing after add-on install
I went to change the art in the TV section and always get a popup asking me to install extendedinfoscript I usually ignore it but this time I installed it, but now I only have about 7 TV shows showing and there are like 20 that used to be in there. I removed extendedscriptinfo but it didn't solve the problem. When I installed the add-on it said something about TVDB using my credentials which didn't make much sense but may be related to the problem.
I tried rescraping the tv show folder, changed the skin to confluence, rebooted, changed the view, no joy. Any suggestions?
I use Isengard 15.1 with Aeon Nox 5.7.3 skin primarily but other skins display the same limited shows.
log: http://pastebin.com/3kDQe6vU
Please enable debugging and upload that new log
debug_log (wiki)
Cheers!
