Full Version: Problema Samba?
Hello to all.
My name is Davide.
I'm new to the forum and I do not hide the fact that I recorded especially for a problem I have with kodi and Raspberry Pi mod 2b I tried to read a little bit on the forum but can not find anything like this ... I guess Smile
I have basically films streaming from pc on Raspberry Pi (Samba) with the latest version of the 6.0.0 Kodi.
When I add the library on the Raspberry Pi he sees me only 226 movies mkv, instead by PC always with Kodi sees 340 .... long ago I had not had this problem but I broke the micro sd and I had to reinstall everything.
I tried to format on Raspberry Pi to clean libraries but nothing to do, continues to see only 226.
I do not know if it is the fault of the fact that I have not moved files to a new folder, but I repeat Kodi from PC sees them all.
Has anyone had the same problem?
It has solved?
Thanks in advance to all and excuse my language but as you may have noticed I write with translate Smile
