Full Version: PVR add on not starting
I have just installed MP and KODI on Windows 10. I have no experience from this SW. I used to run DVB and WMC earlier and Switched to only WMC when I dumped the DVBS. No I use only OTA ATSC.
I can get TV channels on MP TV server set up. When I start KODI I get an error message the the PVR addon doesn't start. I have tried to disable it and enable it again. I have followed the installation from the manuals of both MP and KODI. I'm stuck. Can anyone help.
Can anyone help? With this amount of information, honestly no.
You don't even say what version of Kodi and MP you are using.
OK thanks for the reply, I'm using the latest versions I downloaded this week.
MP 1.12
Kodi 15.2
MP PVR Client 1.10.9
Win10 /64
My HW is:
ASUS My Cinema EHC3150 Combo
Nvidia GeForce 9300 /nForce 730i
Intel Core duo E8400 3.0GHz
Tell me where I can find the logfile and I post it.
Let me know if you need more info.
Log files you'll find under your userprofile\appdata\roaming\kodi.
A dumb question: Have you also installed the TVServerKodi plugin?
I found the log file. Here a link to a log file from a start up of Kodi.
https://onedrive.live.com/redir?resid=71...file%2clog
What can anyone read out of it?
As I said. the PVR ad on doesn't work. I cannot get TV on Kodi. I can watch other video apps and I can watch tv on the Media portal Server in preview.
Thanks again in advance
That is not a dumb question at all. I did not see in the manual that I should install it. If you mean I should I will do so and try again
Thanks Pynktchen!
I found it in the manual and installed it. I suspected it was a rahter simple solution. Thanks
