Full Version: Play V-PID and A-PID TS-Stream!
Pages: 1 2 3 4 5 6 7
ive got some problems with v0.28
Quote:25-07-2004 09:01:32 sys:1: deprecationwarning: non-ascii character '\xe4' in file q:\scripts\dreambox-tv\dreambox-tv v0.28.py on line 132, but no encoding declared; see http://www.python.org/peps/pep-0263.html for details
25-07-2004 09:01:32 traceback (most recent call last):
25-07-2004 09:01:32 file "q:\scripts\dreambox-tv\dreambox-tv v0.28.py", line 42, in ?
25-07-2004 09:01:32
25-07-2004 09:01:32 import xbmc, xbmcgui, os, urllib, time, string, stringio, re, image, imagefile
25-07-2004 09:01:32 importerror
25-07-2004 09:01:32 :
25-07-2004 09:01:32 no module named image
25-07-2004 09:01:32
when i comment out image and imagefile the script work. i'm using xmbc 17-07-2004 build. and the python rar file from xbins. but i dont found the lib's
maybe someone can help me
today i spezialy installed rudream 1.08 for testing dreamtv 0.28
i`ve tested all the scripts(normal + patched) , and no one runs.
only the simplest script 'playtest' runs.
dom
p.s. http auth is off
mietde
with sf 108-8 and the bulldog64 edited version of the script it runs, it does seem kinda buggy, now and again it doesn't work but often it runs :thumbsup:
tried the euro1080 hdtv stream but although it starts streaming i don't get a picture and the screenshot is black.
perhaps it's not possible at all or even only when using a original hdtv cable, dunno.
would be nice if those streams could be viewable, i think the hardware could do it since the xbox does support hdtv, kinda...
haven't tried recording such a hdtv stream and playbacked it later.
that way it is already possible to view it on a pc but if it could be viewable on a xbox :bowdown:
haven't got my hands on a regular 4-2-2 stream...
for normal channels the stream sometimes won't show, it makes the buffer but after a very short piece of sound the streaming seems to stop and all stays black.
same thing for the hdtv stream btw.
after a reboot of the xbox or fidling around with the channels i sometimes do get the streaming working on the same channel it previously didn't, very strange.
well, moving to the next ronald release within a couple of days (when released) hope i will get a bit better stability with that image.
hallo
hab das selbe problem wie lichtl - irgendjemand eine idee Huh
@all
most of the problems related to playing the video stream from dreambox with dreambox-tv script is with the player in xbmc itself.
i say most, because sure there may be problems with the script on different systems e.g. firmware on dreambox,
xbmc version on xbox and so on, but hey it's developing season :p
the player in xbmc is mplayer, and has nothing to do directly with the dreambox-tv python script.
if you get a dialogbox up says "cache fill.." while trying to stream within the dreambox-tv script, the script is working.
xbmc is in continues developing and so is mplayer and ofcoz the dreambox-tv script Wink
please continue to give feedback to help develop a mega dreambox-tv script for xbmc!
thank you all.
kind regards
bulldog64
greetings to geminiserver who started it all :d
(kato2307 @ july 25 2004,17:41 Wrote:hallo
please post in english so i can understand what you write.
if you don't want me to understand, you can post in german. :p
kind regards
bulldog64
(lichtl @ july 25 2004,11:20 Wrote:ive got some problems with v0.28
25-07-2004 09:01:32
25-07-2004 09:01:32
hi lichtl
your xbmc build 17.07 is an ind build and may not work correctly.
i'm using xbox.media.center.v1.0.xbox-htb with python included.
you could also try to install the python image modules from here. place the unzipped files in |xbmc/python/lib/
check also that you have a directory called temp in dreambox-tv root folder.
kind regards
bulldog64
i use ind xbmc from 17.7.
and when i start 0.28 or 0.28 patched, the buttons left
has no functions.
and the text text geminiserver is not shown.
the skript sux before.
the lost font. 14 or 18 i have already copied to xbmc actual skin.
dom
@all
if you got problems running the dreambox-tv script,
please post at least 10-30 last lines from your xbmc.log.
you will find the logfile in the root directory where you have xbmc installed.
this will make it much easyer to answer any bug/norun/noworking related questions.
thank you.
kind regards
bulldog64.
is there allready an script for the dbox2?
:joker:
hi!
here is the next release!!! Wink
<span style='color:red'><span style='font-size:17pt;line-height:100%'>dreambox-tv v0.32</span></span>
download and more screenshots here:
www.xboxconfig.de
[best viewed with: project_mayhem skin !!!] [if you use another skin check the fonts folder in this release!!!!]
Quote:################################################################
# xbmc geminiserver dreambox-tv v0.32 beta!
# comments:
# - this is my first python script guys..
# - if some one own a dreambox and good in python..
# he is welcome to help to create..
# - it is very beta, this means there are some bugs in
# it.. but i think for testing it is ok!
# installation:
# - copy this py to [xbmc]\scripts\dreambox-tv\*.*
# 1. add in the script your dreambox settings
# ip = '192.168.0.110'
# user = 'root'
# password = 'dreambox'
# 2. do not switch chnl on dreambox during streaming
# 3. some chnls can't be stream [don't know why!! dream bug!]
# 4. if the script hang, juste restart xbmc and the script!
# 5. this script ist testet on image release. 1.07.4!
# 6. the record function only write the stream to the hdd
# 7. you can a.t.m only stream [view], or recorder! not both!
# 8. the dbox2 will follow!
# 9. if you use another skin, read the readme file in fonts!
# w.i.p: work in process and future features:
# - make a audio stream choosing, like ac3, ger, eng...
# - create epg view for that channel
# - show doing process [where what]
# - implement error detection is something goes wrong
# - better ui menu: like zap, controll, config, info
# - timeschift for recording..
# - fixing bugs....
# - and more features;)
version history dreambox-tv
v0.32: released !! [testet on dreambox img: <=1.07.4 and >=1.08 ]
add.- fonts folder, read the readme in the folder!!!
add.- changed the text color to red on lcd, osd, scr shots display
add.- some ui tweaks
add.- background, button focus, buttonnofocus images [thx project mayem]
add.- fixed imges in img folder insted of using the skin images
add.- fixed channel list was shown without spaces
add.- fixed bouquet list was shown without spaces
add.- record icon during recording!
add.- new images folder
v0.31:
add.- ask to play the recordet file after recording
add.- recording done message
add.- recording goes on after exit dreambox-tv
add.- recording enter how much mbytes should i record
add.- recording function write by fixed mbytes
v0.30:
add.- on start make also lcdshot and screen shot for the cur channel
add.- connecting progress on starting, try to connecting to dreambox 4x time
add.- cleanup dreambox-tv files on exit!
add.- tmp_folder: warning! do not change this folder! if you use root all files will be deletet!
add.- cleaup: remove all temp files and create new temp..
add.- set version between 1.07 and 1.08 hope this will fix some problems
add.- global message language
add.- add encode strings to utf-8 [for all settings]
add.- show current channle on start up, instead show bouquet thx goes to "bulldog64"
v0.29:
add.- global command settings to be compatible in future!
add.- cahnged the ui for scrennshot display!
add.- changed the vapid detection! thx goes to "bulldog64"
add.- removed the dialogs on screenshot...
add.- on zap also show in background the current screen shot!
v0.28: released!
add.- some ui tweaks..
add.- lcd view during zap;)!
add.- lcd-shot on ui
add.- all temp files now and must be in \temp
add.- new folder in dreambox-tv root temp!!
add.- base config.ini [but w.i.p]
v0.27:
add.- set name for each recordet file tdate!
add.- start recording choose yesno
add.- show error is vapid not avaiblible on the current chnl
add.- ask yn if you want to exit on [back!]
v0.26:
add.- switch from channel back to bouquets <>
add.- dreambox controll: onscreendisplay [osdp] shot and show the picture
add.- create dreambox controll: lcd display shot and show the picture
add.- record to hdd [current with python, only for testing! but i will implement this
function directly into xbmc, so it will be then easy to start and stop the
recording during view! it will also possible to stream another channel and
record another one! if they im the same network.]
v0.25:
add.- dreambox controll: standby
add.- dreambox controll: wakeup
add.- dreambox controll: screenshot and show the picture
add.- zapto the channel
add.- receive all channels and bouquets
add.- analyse an create the channel list..
v0.24:
add.- created ui
v0.1x:
add.- connect and get the current stream
add.- initial release
regards
geminiserver!
hi,
i tried the verion 0.32 now, but it still won´t work...
sometimes the stream works, but just sometimes and all the other things never wok...
here is my log file:
05-12-8907 19:49:59 -->python initialized<--
05-12-8907 19:50:00
05-12-8907 19:50:01 cleaning dreambox-tv enviroment!
05-12-8907 19:50:01
05-12-8907 19:50:01 removed
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\dreambox-tv.html
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\tmp_chnbq.txt
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\tmp_chnrf.txt
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\tmp_bouquetsbq.txt
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\tmp_bouquetsrf.txt
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\lcdshot.png
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\screenshot.bmp
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 q:\scripts\dreambox-tv\temp\osdshot.png
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01
05-12-8907 19:50:01 connecting to dreambox.....
05-12-8907 19:50:01
05-12-8907 19:50:01 reading source from dreambox!
05-12-8907 19:50:01
05-12-8907 19:50:01 writing source to local temp
05-12-8907 19:50:01
05-12-8907 19:50:01 writing temp done.
05-12-8907 19:50:01
05-12-8907 19:50:01 starting dreambox-tv ui!
05-12-8907 19:50:01
05-12-8907 19:50:35 1. connecting to get vpid & apid
05-12-8907 19:50:35
05-12-8907 19:50:35 2.got the vpid:6e
05-12-8907 19:50:35
05-12-8907 19:50:35 3.got the apid:78
05-12-8907 19:50:35
05-12-8907 19:50:35 4.created the play string
-->http://xxxx:[email protected]:31339/6e,78
ok! then lets try to stream!
05-12-8907 19:50:35
05-12-8907 19:50:35 mplayer play:http://http://xxxx:[email protected]:31339/6e,78 cachesize:4096
05-12-8907 19:50:35 flipping bi-directional subtitles disabled
05-12-8907 19:50:36 stating file q:\mplayer\http://xxxx:[email protected]:31339/6e,78.conf
05-12-8907 19:50:42 detected video. cachesize is now 8192, (was 4096)
@bULLdOG64
please, would you give us a new version for 108.
thx and best regards
craxxWink
@Craxx
dreambox-tv v0.32 works also with the 1.08!
you need to set the dreamboximg to 1
look in dreambox-tv v0.32.py
Quote:##################################################################
# set here 0 or 1 --> 0 is for <=1.07.4 and 1 is for >= 1.08
dreamboximg = '0'
egards
geminiserver
@wasistwas
did you edit the logfile ? xxxx ? if you enter xxxx instead of the normal ip it won't work!
but if you just edit the log to prevent view your ip lol...
it seems that you are the one who's image not stable enought.. the script work perfect.. and it creates a play string.. and normly it should work!
regards
geminiserver
