2015-11-27, 05:00
MK808b Plus
Kodi 15.2
When watching a video with 29.97 or 30 fps, every few seconds the video will freeze, then jump forward. I have also increased the buffer in advancedsettings.xml and I can see the buffer is not running out, so it should not be a network issue. I have tried the default settings and all combinations of "sync playback to display" and "adjust display refresh rate" but continue to have the same issue.
If I use SPMC 13.2 with default settings, the same video plays fine.
24 fps videos play fine on both kodi and spmc
debug https://paste.ee/p/3kspM
This looks like the interesting bit to me as it starts and continues for the entire video.
Kodi 15.2
14:13:56 T:1852773872 DEBUG: Previous line repeats 11 times.
14:13:56 T:1852773872 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
14:13:56 T:1852773872 DEBUG: CDVDPlayerVideo::CalcDropRequirement - dropped in decoder, Sleeptime: -0.044890, Bufferlevel: 1, Gain: 0.233567
14:13:57 T:1852773872 DEBUG: Previous line repeats 27 times.
14:13:57 T:1852773872 DEBUG: CDVDPlayerVideo::CalcDropRequirement - dropped in decoder, Sleeptime: -0.078070, Bufferlevel: 1, Gain: 0.100099
14:13:57 T:1852773872 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
14:13:58 T:1852773872 DEBUG: Previous line repeats 20 times.
14:13:58 T:1852773872 DEBUG: CDVDPlayerVideo::CalcDropRequirement - dropped in decoder, Sleeptime: -0.079494, Bufferlevel: 1, Gain: 0.100099
14:13:58 T:1852773872 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
14:13:58 T:1852773872 DEBUG: Previous line repeats 24 times.
