Full Version: Openelec & airplay
Hello,
I'm running version 6 and I'm having issues with airplay from my ipad apps (BT sport & youtube) to openelec. The pad sees that there is an airplay device and when I start to play openelec goes black for a second and then goes back to a normal display.
I've had a search around and can't find any real solutions that seems to work for me. Is anyone else having this problem or am I doing something wrong.
It worked under openelec 5, but it seems to be as I have upgraded?
Does anyone have any suggestions or is this a known issue??
youtube app is not supported because of the way google changed it a year ago. Can't tell much about BT sport but it might be the same reason. You just use the "wrong" apps. Airplay support is limited in kodi and the more apple changes the worse it gets. At some point it will be removed from Kodi as a result of this.
