2015-11-27, 20:02
Installed OSMC awhile back using the img Everything has been great since upgrading to 2amp power supply ! HDhomerun ran smooth
mile:
I just coudnt keep well enough alone !!!! I installed a new skin NEON and by accident the setting button was removed...... So had to wipe the card and start over. I found your new wizard that uses windows to self install OSMC to Sd card wow ! I like that finally someone put it all together
mile:
mile:
Here's my problem after the new install of OSMC the HDhomerun addon the HD channels now studder and the app goes to restart screen.
Should I go back to the old method and use the img install the older version ?
