2015-11-29, 15:32
I have what seems a simple problem but I can't seem to solve it so I'm hoping someone can help.
I am trying to play a particular video stream in KODI 15.2 using the standard player this is what I do:-
I choose the stream link
KODI says its 'opening stream'
after 5 - 10 secs the 'opening stream' message goes away and for a microsecond it seems to open the stream
it then drops back the same stream link I previously chose I then click on the link a second time
it does exactly the same thing except after 5 - 10 seconds it says 'check error log'
I then go into the logs and see that it's trying to connect to the stream but the standard player doesn't support it.
I then add playercorefactory.xml to the userdata folder and restart kodi.
I choose the same stream link again, this time bringing up the context menu and choosing each of the external players, it does the same thing.
I check the error logs to find the external players I'm choosing aren't installed so I install:-
sopcast
vlc player
mx player
I reboot KODI and try again, this time choosing the context menu and choosing vlc and mx player, I get the same problem
When I choose sopcast to play the stream it plays ok.
The stream is a .MP4 file so I assume VLC and MX Player should play these files.
KODI 15.2 is installed on AMAZON FIRE TV
I have ES File explorer installed and can confirm the playercorefactory.xml information for the external players are pointing to the correct folder structure on the FIRE TV.
I'm at a loss to where to go from here. I'm quite technical on most things and if someone can advise where to go from this point I'd be very grateful.
Mike
sopcast
vlc player
mx player
Mike
