2015-11-29, 16:53
Hi everyone,
I have used xmbcbuntu for a while on my machine, but I just moved to a new home, I decided to refresh my setup and make a clean install.
My PC is connected via HDMI to a Denon 2312 amplifier, as before.
Back in the days, I had no trouble getting HD audio codecs to work, but I'm facing a new challenge.
Here is the PC uname -a :
and here is how kodi.log sees the amplifier :
I have removed pulseaudio to use only ALSA, and the passtrough options are available and activated in kodi (even DTSHD and TRUEHD).
All the other codecs work well in passtrough, but these two won't work : video but no sound, not recognized but the amp.
If I uncheck the passtrough options, sound is working (but obviously without passtrough).
I have read here and there othes issues of the same kind while in 24p, so I tried to force 60Hz and still no sound.
I have read also that there might be a problem if the amp was detected only in 6 channels, but it's not the case (see kodi log).
I know for sure that it has worked in the past, so there must be something I do wrong this time....
Any help/ideas please ?
A great thanks in advance !
Update : I forgot to mention that I used Kodi (15.2 Git:02e7013)
Quote:Linux mendoza 3.19.0-33-generic #38~14.04.1-Ubuntu SMP Fri Nov 6 18:17:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
guichan@mendoza:~$
Quote:09:30:50 T:140204238219200 NOTICE: Device 4
09:30:50 T:140204238219200 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=0
09:30:50 T:140204238219200 NOTICE: m_displayName : HDA NVidia
09:30:50 T:140204238219200 NOTICE: m_displayNameExtra: HDMI
09:30:50 T:140204238219200 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
09:30:50 T:140204238219200 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
09:30:50 T:140204238219200 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
09:30:50 T:140204238219200 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
