[UPDATE] I did some further tests and resuming seems to be broken only under Chinese (both simplified and traditional). I tested Germany, Japanese, Korean and all flavors of English, they all worked fine. What would be the issue?
Hi all, I am recently configuring a Kodi system for my parents house where they can play and sync progress between multiple devices through SMB and MySQL. However I am having trouble with two Android 5+ devices, in that these two devices never resume and always flush out the progress data from MySQL. After a lot of tests I realized the interface language selection is the killer.
Exactly after switching from English to another language, the resuming functionality is broken. If I move back the "guisettings.xml" before the language switch, the resuming functionality is repaired. I compared the "guisettings.xml" file before and after the language switch, and only three lines are different, so I believe there are some coding bugs inside the APK.
By the way this bug does not show up on Android 4.4, Windows or Linux. Only on Android 5+.
XML before the language switch:
<settings>
<accessibility>
<audiohearing default="true">false</audiohearing>
<audiovisual default="true">false</audiovisual>
<subhearing default="true">false</subhearing>
</accessibility>
<audiocds>
<autoaction default="true">0</autoaction>
<ejectonrip default="true">true</ejectonrip>
<encoder default="true">audioencoder.xbmc.builtin.wav</encoder>
<recordingpath default="true"></recordingpath>
<trackpathformat default="true">%A/%A - %B/[%N. ][%A - ]%T</trackpathformat>
<usecddb default="true">true</usecddb>
</audiocds>
<audiooutput>
<ac3passthrough default="true">true</ac3passthrough>
<ac3transcode default="true">false</ac3transcode>
<audiodevice default="true">AUDIOTRACK:AudioTrack</audiodevice>
<channels default="true">1</channels>
<config default="true">2</config>
<dtshdpassthrough default="true">false</dtshdpassthrough>
<dtspassthrough default="true">false</dtspassthrough>
<eac3passthrough default="true">false</eac3passthrough>
<guisoundmode default="true">1</guisoundmode>
<maintainoriginalvolume default="true">true</maintainoriginalvolume>
<passthrough default="true">false</passthrough>
<passthroughdevice default="true">AUDIOTRACK:AudioTrack</passthroughdevice>
<processquality default="true">30</processquality>
<samplerate default="true">48000</samplerate>
<stereoupmix default="true">false</stereoupmix>
<streamsilence default="true">1</streamsilence>
<truehdpassthrough default="true">false</truehdpassthrough>
</audiooutput>
<cache>
<harddisk default="true">256</harddisk>
</cache>
<cacheaudio>
<dvdrom default="true">256</dvdrom>
<internet default="true">256</internet>
<lan default="true">256</lan>
</cacheaudio>
<cachedvd>
<dvdrom default="true">2048</dvdrom>
<lan default="true">2048</lan>
</cachedvd>
<cacheunknown>
<internet default="true">4096</internet>
</cacheunknown>
<cachevideo>
</cachevideo>
<debug>
<extralogging default="true">true</extralogging>
<screenshotpath default="true"></screenshotpath>
<setextraloglevel default="true">32768</setextraloglevel>
<showloginfo default="true">false</showloginfo>
</debug>
<disc>
<playback default="true">0</playback>
</disc>
<dvds>
<automenu default="true">false</automenu>
<autorun default="true">false</autorun>
<playerregion default="true">0</playerregion>
</dvds>
<epg>
<daystodisplay default="true">3</daystodisplay>
<epgupdate default="true">120</epgupdate>
<hidenoinfoavailable default="true">true</hidenoinfoavailable>
<ignoredbforclient default="true">false</ignoredbforclient>
<preventupdateswhileplayingtv default="true">false</preventupdateswhileplayingtv>
<selectaction default="true">2</selectaction>
</epg>
<filelists>
<allowfiledeletion default="true">false</allowfiledeletion>
<ignorethewhensorting default="true">true</ignorethewhensorting>
<showaddsourcebuttons default="true">true</showaddsourcebuttons>
<showextensions default="true">true</showextensions>
<showhidden default="true">false</showhidden>
<showparentdiritems default="true">true</showparentdiritems>
</filelists>
<general>
<addonbrokenfilter default="true">true</addonbrokenfilter>
<addonforeignfilter default="true">false</addonforeignfilter>
<addonnotifications default="true">true</addonnotifications>
<addonupdates default="true">0</addonupdates>
<settinglevel>3</settinglevel>
<systemtotaluptime>4</systemtotaluptime>
</general>
<input>
<enablejoystick default="true">true</enablejoystick>
<enablemouse default="true">true</enablemouse>
</input>
<karaoke>
<autopopupselector default="true">false</autopopupselector>
<charset default="true">DEFAULT</charset>
<enabled default="true">false</enabled>
<font default="true">arial.ttf</font>
<fontcolors default="true">0</fontcolors>
<fontheight default="true">36</fontheight>
</karaoke>
<locale>
<audiolanguage default="true">original</audiolanguage>
<country>USA (24h)</country>
<keyboardlayouts default="true">English QWERTY</keyboardlayouts>
<language default="true">resource.language.en_gb</language>
<longdateformat default="true">regional</longdateformat>
<shortdateformat default="true">regional</shortdateformat>
<speedunit default="true">regional</speedunit>
<subtitlelanguage default="true">original</subtitlelanguage>
<temperatureunit default="true">regional</temperatureunit>
<timeformat default="true">regional</timeformat>
<timezone default="true"></timezone>
<timezonecountry default="true"></timezonecountry>
<use24hourclock default="true">regional</use24hourclock>
</locale>
<lookandfeel>
<enablerssfeeds default="true">true</enablerssfeeds>
<font>Arial</font>
<rssedit default="true"></rssedit>
<skin>skin.re-touched</skin>
<skincolors default="true">SKINDEFAULT</skincolors>
<skintheme default="true">SKINDEFAULT</skintheme>
<skinzoom default="true">0</skinzoom>
<soundskin default="true">resource.uisounds.confluence</soundskin>
<startupwindow default="true">10000</startupwindow>
</lookandfeel>
<masterlock>
<maxretries default="true">3</maxretries>
<startuplock default="true">false</startuplock>
</masterlock>
<musicfiles>
<findremotethumbs default="true">true</findremotethumbs>
<librarytrackformat default="true"></librarytrackformat>
<librarytrackformatright default="true"></librarytrackformatright>
<nowplayingtrackformat default="true"></nowplayingtrackformat>
<nowplayingtrackformatright default="true"></nowplayingtrackformatright>
<trackformat default="true">[%N. ]%A - %T</trackformat>
<trackformatright default="true">%D</trackformatright>
<usetags default="true">true</usetags>
</musicfiles>
<musiclibrary>
<albumsscraper default="true">metadata.album.universal</albumsscraper>
<artistsscraper default="true">metadata.artists.universal</artistsscraper>
<backgroundupdate default="true">false</backgroundupdate>
<downloadinfo default="true">false</downloadinfo>
<overridetags default="true">false</overridetags>
<showallitems default="true">true</showallitems>
<showcompilationartists default="true">true</showcompilationartists>
<updateonstartup default="true">false</updateonstartup>
</musiclibrary>
<musicplayer>
<autoplaynextitem default="true">true</autoplaynextitem>
<crossfade default="true">0</crossfade>
<crossfadealbumtracks default="true">true</crossfadealbumtracks>
<queuebydefault default="true">false</queuebydefault>
<replaygainavoidclipping default="true">false</replaygainavoidclipping>
<replaygainnogainpreamp default="true">89</replaygainnogainpreamp>
<replaygainpreamp default="true">89</replaygainpreamp>
<replaygaintype default="true">1</replaygaintype>
<seekdelay default="true">750</seekdelay>
<seeksteps default="true">-60,-30,-10,10,30,60</seeksteps>
<visualisation default="true">visualization.glspectrum</visualisation>
</musicplayer>
<mymusic>
<defaultlibview default="true"></defaultlibview>
<songthumbinvis default="true">false</songthumbinvis>
<startwindow default="true">10501</startwindow>
<playlist>
<repeat>false</repeat>
<shuffle>false</shuffle>
</playlist>
<needsupdate>0</needsupdate>
</mymusic>
<myvideos>
<extractchapterthumbs default="true">true</extractchapterthumbs>
<extractflags default="true">true</extractflags>
<extractthumb default="true">true</extractthumb>
<flatten default="true">false</flatten>
<replacelabels default="true">true</replacelabels>
<selectaction default="true">1</selectaction>
<stackvideos default="true">false</stackvideos>
<watchmodemovies>0</watchmodemovies>
<watchmodetvshows>0</watchmodetvshows>
<watchmodemusicvideos>0</watchmodemusicvideos>
<playlist>
</playlist>
</myvideos>
<network>
<bandwidth default="true">0</bandwidth>
<httpproxypassword default="true"></httpproxypassword>
<httpproxyport default="true">8080</httpproxyport>
<httpproxyserver default="true"></httpproxyserver>
<httpproxytype default="true">0</httpproxytype>
<httpproxyusername default="true"></httpproxyusername>
<usehttpproxy default="true">false</usehttpproxy>
</network>
<pictures>
<displayresolution default="true">14</displayresolution>
<generatethumbs default="true">true</generatethumbs>
<showvideos default="true">true</showvideos>
<useexifrotation default="true">true</useexifrotation>
</pictures>
<powermanagement>
<displaysoff default="true">0</displaysoff>
<shutdownstate default="true">0</shutdownstate>
<shutdowntime default="true">0</shutdowntime>
<wakeonaccess default="true">false</wakeonaccess>
</powermanagement>
<pvrmanager>
<backendchannelorder default="true">true</backendchannelorder>
<hideconnectionlostwarning default="true">false</hideconnectionlostwarning>
<syncchannelgroups default="true">true</syncchannelgroups>
<usebackendchannelnumbers default="true">false</usebackendchannelnumbers>
</pvrmanager>
<pvrmenu>
<closechannelosdonswitch default="true">true</closechannelosdonswitch>
<displaychannelinfo default="true">5</displaychannelinfo>
<iconpath default="true"></iconpath>
</pvrmenu>
<pvrparental>
<duration default="true">300</duration>
<pin default="true"></pin>
</pvrparental>
<pvrplayback>
<channelentrytimeout default="true">0</channelentrytimeout>
<confirmchannelswitch default="true">false</confirmchannelswitch>
<fps default="true">0</fps>
<playminimized default="true">true</playminimized>
<scantime default="true">10</scantime>
<signalquality default="true">true</signalquality>
<startlast default="true">0</startlast>
</pvrplayback>
<pvrpowermanagement>
<backendidletime default="true">15</backendidletime>
<dailywakeup default="true">false</dailywakeup>
<dailywakeuptime default="true">00:00:00</dailywakeuptime>
<prewakeup default="true">15</prewakeup>
<setwakeupcmd default="true"></setwakeupcmd>
</pvrpowermanagement>
<pvrrecord>
<defaultlifetime default="true">99</defaultlifetime>
<defaultpriority default="true">50</defaultpriority>
<instantrecordtime default="true">120</instantrecordtime>
<marginend default="true">0</marginend>
<marginstart default="true">0</marginstart>
<timernotifications default="true">true</timernotifications>
</pvrrecord>
<scrapers>
<moviesdefault default="true">metadata.themoviedb.org</moviesdefault>
<musicvideosdefault default="true">metadata.musicvideos.theaudiodb.com</musicvideosdefault>
<tvshowsdefault default="true">metadata.tvdb.com</tvshowsdefault>
</scrapers>
<screensaver>
<mode></mode>
<time default="true">3</time>
<usedimonpause default="true">true</usedimonpause>
<usemusicvisinstead default="true">true</usemusicvisinstead>
</screensaver>
<services>
<airplay default="true">false</airplay>
<airplayios8compat default="true">true</airplayios8compat>
<airplaypassword default="true"></airplaypassword>
<airplayvolumecontrol default="true">true</airplayvolumecontrol>
<devicename default="true">Kodi</devicename>
<esallinterfaces default="true">false</esallinterfaces>
<escontinuousdelay default="true">25</escontinuousdelay>
<esenabled default="true">true</esenabled>
<esinitialdelay default="true">750</esinitialdelay>
<esmaxclients default="true">20</esmaxclients>
<esport default="true">9777</esport>
<esportrange default="true">10</esportrange>
<upnpannounce default="true">true</upnpannounce>
<upnpcontroller default="true">false</upnpcontroller>
<upnplookforexternalsubtitles default="true">false</upnplookforexternalsubtitles>
<upnprenderer default="true">false</upnprenderer>
<upnpserver default="true">false</upnpserver>
<useairplaypassword default="true">false</useairplaypassword>
<webserver default="true">false</webserver>
<webserverpassword default="true"></webserverpassword>
<webserverport default="true">8080</webserverport>
<webserverusername default="true">kodi</webserverusername>
<webskin default="true">webinterface.default</webskin>
<zeroconf default="true">true</zeroconf>
</services>
<slideshow>
<displayeffects default="true">true</displayeffects>
<shuffle default="true">false</shuffle>
<staytime default="true">5</staytime>
</slideshow>
<smb>
<winsserver default="true">0.0.0.0</winsserver>
<workgroup default="true">WORKGROUP</workgroup>
</smb>
<subtitles>
<align default="true">0</align>
<color default="true">1</color>
<custompath default="true"></custompath>
<downloadfirst default="true">false</downloadfirst>
<height default="true">28</height>
<languages default="true">English</languages>
<movie default="true"></movie>
<overrideassfonts default="true">false</overrideassfonts>
<parsecaptions default="true">false</parsecaptions>
<pauseonsearch default="true">true</pauseonsearch>
<stereoscopicdepth default="true">0</stereoscopicdepth>
<storagemode default="true">0</storagemode>
<style default="true">1</style>
<tv default="true"></tv>
</subtitles>
<system>
<playlistspath>special://profile/playlists/</playlistspath>
</system>
<videolibrary>
<actorthumbs default="true">true</actorthumbs>
<flattentvshows default="true">1</flattentvshows>
<groupmoviesets default="true">false</groupmoviesets>
<showunwatchedplots default="true">true</showunwatchedplots>
<tvshowsincludeallseasonsandspecials default="true">0</tvshowsincludeallseasonsandspecials>
<tvshowsselectfirstunwatcheditem default="true">0</tvshowsselectfirstunwatcheditem>
</videolibrary>
<videoplayer>
<adjustrefreshrate default="true">0</adjustrefreshrate>
<autoplaynextitem default="true">false</autoplaynextitem>
<errorinaspect default="true">0</errorinaspect>
<hqscalers default="true">0</hqscalers>
<pauseafterrefreshchange default="true">0</pauseafterrefreshchange>
<preferdefaultflag default="true">true</preferdefaultflag>
<prefervaapirender default="true">true</prefervaapirender>
<quitstereomodeonstop default="true">true</quitstereomodeonstop>
<rendermethod default="true">0</rendermethod>
<seeksteps default="true">-600,-300,-180,-60,-30,-10,10,30,60,180,300,600</seeksteps>
<stereoscopicplaybackmode default="true">0</stereoscopicplaybackmode>
<stretch43 default="true">0</stretch43>
<teletextenabled default="true">true</teletextenabled>
<teletextscale default="true">true</teletextscale>
<useamcodec>false</useamcodec>
<usedisplayasclock default="true">false</usedisplayasclock>
<usedxva2 default="true">true</usedxva2>
<usemediacodec default="true">true</usemediacodec>
<useomx default="true">true</useomx>
<useomxplayer default="true">true</useomxplayer>
<usestagefright default="true">true</usestagefright>
<usevaapi default="true">true</usevaapi>
<usevaapimpeg2 default="true">true</usevaapimpeg2>
<usevaapimpeg4 default="true">true</usevaapimpeg4>
<usevaapivc1 default="true">true</usevaapivc1>
<usevda default="true">true</usevda>
<usevdpau default="true">true</usevdpau>
<usevdpaumixer default="true">true</usevdpaumixer>
<usevdpaumpeg2 default="true">true</usevdpaumpeg2>
<usevdpaumpeg4 default="true">false</usevdpaumpeg4>
<usevdpauvc1 default="true">true</usevdpauvc1>
<usevideotoolbox default="true">true</usevideotoolbox>
</videoplayer>
<videoscreen>
<blankdisplays default="true">false</blankdisplays>
<fakefullscreen default="true">true</fakefullscreen>
<limitedrange default="true">false</limitedrange>
<monitor default="true">Default</monitor>
<preferedstereoscopicmode default="true">100</preferedstereoscopicmode>
<resolution default="true">16</resolution>
<screen default="true">0</screen>
<screenmode default="true">DESKTOP</screenmode>
<stereoscopicmode default="true">0</stereoscopicmode>
<vsync default="true">2</vsync>
</videoscreen>
<weather>
<addon default="true"></addon>
<currentlocation default="true">1</currentlocation>
</weather>
<window>
<height default="true">480</height>
<width default="true">720</width>
</window>
<skinsettings>
<setting type="bool" name="skin.confluence.Use_Startup_Playlist">false</setting>
<setting type="bool" name="skin.confluence.UseCustomBackground">false</setting>
<setting type="bool" name="skin.confluence.HideBackGroundFanart">false</setting>
<setting type="bool" name="skin.confluence.ShowBackgroundVideo">false</setting>
<setting type="bool" name="skin.confluence.ShowBackgroundVis">false</setting>
<setting type="bool" name="skin.confluence.HomepageHideRecentlyAddedVideo">false</setting>
<setting type="bool" name="skin.confluence.HomepageHideRecentlyAddedAlbums">false</setting>
<setting type="bool" name="skin.confluence.homepageWeatherinfo">false</setting>
<setting type="bool" name="skin.confluence.homepageMusicinfo">false</setting>
<setting type="bool" name="skin.confluence.homepageVideoinfo">false</setting>
<setting type="bool" name="skin.confluence.HomeMenuNoMovieButton">false</setting>
<setting type="bool" name="skin.confluence.HomeMenuNoTVShowButton">false</setting>
<setting type="bool" name="skin.confluence.HomeMenuNoWeatherButton">false</setting>
<setting type="bool" name="skin.confluence.HomeMenuNoPicturesButton">false</setting>
<setting type="bool" name="skin.confluence.HomeMenuNoVideosButton">false</setting>
<setting type="bool" name="skin.confluence.HomeMenuNoMusicButton">false</setting>
<setting type="bool" name="skin.confluence.HomeMenuNoProgramsButton">false</setting>
<setting type="bool" name="skin.confluence.HideFilenameFlagging">false</setting>
<setting type="bool" name="skin.confluence.View508HideInfo">false</setting>
<setting type="bool" name="skin.confluence.AutoScroll">false</setting>
<setting type="bool" name="skin.confluence.FirstTimeRun">true</setting>
<setting type="bool" name="skin.re-touched.UseCustomBackground">false</setting>
<setting type="bool" name="skin.re-touched.HideVideoBackground">false</setting>
<setting type="bool" name="skin.re-touched.HideVizBackground">false</setting>
<setting type="bool" name="skin.re-touched.MediaSubMenuVisible">false</setting>
<setting type="bool" name="skin.re-touched.ShowHomeButtonLiveTV">false</setting>
<setting type="bool" name="skin.re-touched.HideHomeButtonVideo">false</setting>
<setting type="bool" name="skin.re-touched.HideHomeButtonMovies">false</setting>
<setting type="bool" name="skin.re-touched.HideHomeButtonTVShows">false</setting>
<setting type="bool" name="skin.re-touched.HideHomeButtonMusic">false</setting>
<setting type="bool" name="skin.re-touched.HideHomeButtonPictures">false</setting>
<setting type="bool" name="skin.re-touched.HideHomeButtonPrograms">true</setting>
<setting type="bool" name="skin.re-touched.HideHomeButtonWeather">true</setting>
<setting type="bool" name="skin.re-touched.PlayerControlsShowAudioInfo">false</setting>
<setting type="bool" name="skin.re-touched.PlayerControlsShowVideoInfo">false</setting>
<setting type="bool" name="skin.re-touched.PlayerControlsSubMenuVisible">false</setting>
<setting type="string" name="skin.confluence.CustomBackgroundPath"></setting>
<setting type="string" name="skin.confluence.HomeVideosButton1"></setting>
<setting type="string" name="skin.confluence.HomeVideosButton2"></setting>
<setting type="string" name="skin.confluence.HomeVideosButton3"></setting>
<setting type="string" name="skin.confluence.HomeVideosButton4"></setting>
<setting type="string" name="skin.confluence.HomeVideosButton5"></setting>
<setting type="string" name="skin.confluence.HomeMusicButton1"></setting>
<setting type="string" name="skin.confluence.HomeMusicButton2"></setting>
<setting type="string" name="skin.confluence.HomeMusicButton3"></setting>
<setting type="string" name="skin.confluence.HomeMusicButton4"></setting>
<setting type="string" name="skin.confluence.HomeMusicButton5"></setting>
<setting type="string" name="skin.confluence.HomePictureButton1"></setting>
<setting type="string" name="skin.confluence.HomePictureButton2"></setting>
<setting type="string" name="skin.confluence.HomePictureButton3"></setting>
<setting type="string" name="skin.confluence.HomePictureButton4"></setting>
<setting type="string" name="skin.confluence.HomePictureButton5"></setting>
<setting type="string" name="skin.confluence.HomeProgramButton1"></setting>
<setting type="string" name="skin.confluence.HomeProgramButton2"></setting>
<setting type="string" name="skin.confluence.HomeProgramButton3"></setting>
<setting type="string" name="skin.confluence.HomeProgramButton4"></setting>
<setting type="string" name="skin.confluence.HomeProgramButton5"></setting>
<setting type="string" name="skin.re-touched.CustomBackground"></setting>
<setting type="string" name="skin.re-touched.SkinSettings">1</setting>
<setting type="string" name="skin.re-touched.HomeAddonButton1"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton2"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton3"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton4"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton5"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton6"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton7"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton8"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton9"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton10"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton11"></setting>
<setting type="string" name="skin.re-touched.HomeAddonButton12"></setting>
<setting type="string" name="skin.re-touched.HomeContentPage"></setting>
</skinsettings>
<resolutions />
<defaultvideosettings>
<deinterlacemode>1</deinterlacemode>
<interlacemethod>1</interlacemethod>
<scalingmethod>1</scalingmethod>
<noisereduction>0.000000</noisereduction>
<postprocess>false</postprocess>
<sharpness>0.000000</sharpness>
<viewmode>0</viewmode>
<zoomamount>1.000000</zoomamount>
<pixelratio>1.000000</pixelratio>
<verticalshift>0.000000</verticalshift>
<volumeamplification>0.000000</volumeamplification>
<outputtoallspeakers>false</outputtoallspeakers>
<showsubtitles>true</showsubtitles>
<brightness>50.000000</brightness>
<contrast>50.000000</contrast>
<gamma>20.000000</gamma>
<audiodelay>0.000000</audiodelay>
<subtitledelay>0.000000</subtitledelay>
<nonlinstretch>false</nonlinstretch>
<stereomode>0</stereomode>
</defaultvideosettings>
<viewstates>
<musicfiles>
<viewmode>720896</viewmode>
<sortmethod>1</sortmethod>
<sortorder>1</sortorder>
<sortattributes>0</sortattributes>
</musicfiles>
<musiclastfm>
<viewmode>65536</viewmode>
</musiclastfm>
<musicnavalbums>
</musicnavalbums>
<musicnavartists>
</musicnavartists>
<musicnavsongs>
</musicnavsongs>
<pictures>
<viewmode>328180</viewmode>
</pictures>
<programs>
</programs>
<videofiles>
<sortmethod>0</sortmethod>
<sortorder>0</sortorder>
</videofiles>
<videonavactors>
</videonavactors>
<videonavepisodes>
<sortmethod>21</sortmethod>
</videonavepisodes>
<videonavgenres>
</videonavgenres>
<videonavmusicvideos>
</videonavmusicvideos>
<videonavseasons>
</videonavseasons>
<videonavtitles>
</videonavtitles>
<videonavtvshows>
</videonavtvshows>
<videonavyears>
</videonavyears>
</viewstates>
<audio>
<mute>false</mute>
<fvolumelevel>1.000000</fvolumelevel>
</audio>
</settings>
XML after the language switch
<settings>
<accessibility>
</accessibility>
<audiocds>
</audiocds>
<audiooutput>
</audiooutput>
<cache>
</cache>
<cacheaudio>
</cacheaudio>
<cachedvd>
</cachedvd>
<cacheunknown>
</cacheunknown>
<cachevideo>
</cachevideo>
<debug>
</debug>
<disc>
</disc>
<dvds>
</dvds>
<epg>
</epg>
<filelists>
</filelists>
<general>
<systemtotaluptime>5</systemtotaluptime>
</general>
<input>
</input>
<karaoke>
</karaoke>
<locale>
<country>鍙板寳 (24h)</country>
<language>resource.language.zh_tw</language>
</locale>
<lookandfeel>
<font>Arial</font>
</lookandfeel>
<masterlock>
</masterlock>
<musicfiles>
</musicfiles>
<musiclibrary>
</musiclibrary>
<musicplayer>
</musicplayer>
<mymusic>
<playlist>
</playlist>
</mymusic>
<myvideos>
<playlist>
</playlist>
</myvideos>
<network>
</network>
<pictures>
</pictures>
<powermanagement>
</powermanagement>
<pvrmanager>
</pvrmanager>
<pvrmenu>
</pvrmenu>
<pvrparental>
</pvrparental>
<pvrplayback>
</pvrplayback>
<pvrrecord>
</pvrrecord>
<scrapers>
</scrapers>
<screensaver>
<mode></mode>
</screensaver>
<services>
</services>
<slideshow>
</slideshow>
<smb>
</smb>
<subtitles>
</subtitles>
<system>
</system>
<videolibrary>
</videolibrary>
<videoplayer>
</videoplayer>
<videoscreen>
</videoscreen>
<weather>
</weather>
<window>
</window>
<skinsettings>
</skinsettings>
<resolutions />
<viewstates>
<musicfiles>
</musicfiles>
<musiclastfm>
</musiclastfm>
<musicnavalbums>
</musicnavalbums>
<musicnavartists>
</musicnavartists>
<musicnavsongs>
</musicnavsongs>
<pictures>
</pictures>
<programs>
</programs>
<videofiles>
</videofiles>
<videonavactors>
</videonavactors>
<videonavepisodes>
</videonavepisodes>
<videonavgenres>
</videonavgenres>
<videonavseasons>
</videonavseasons>
<videonavtitles>
</videonavtitles>
<videonavtvshows>
</videonavtvshows>
<videonavyears>
</videonavyears>
</viewstates>
<audio>
<mute>false</mute>
</audio>
</settings>
Can you get us a
debug log (wiki) of when this happens?
Hi AndreasBVB or anybody, sorry to ask a related question but not directly to this post. I'm new to kodi and using kodi on a Samsung S5 Android phone to listen to music/songs. How can I install a keyboard so that I can input Chinese to search the song list? I don't know much about programming and just an entry-level user. Thank you so much for your help!
