Full Version: In progress doesnt work
Hey
Updated my Firetv boxes to the latest stable isengard release and now my Titan in progress buttons don't do anything.
There was an issue with my db so i moved it from my readynas to a windows server.
Anything i can try or should do?
What do you mean with in progress buttons?
(2015-11-30, 00:35)marcelveldt Wrote: [ -> ]What do you mean with in progress buttons?
Under tv shows i have TV Shows in Progress
and under movies, recently added.
Nothing works on the main tv and movie options, so not of the sub menu options
(2015-12-01, 21:02)purplechris Wrote: [ -> ]Under tv shows i have TV Shows in Progress
Something's wrong with your shortcuts.
You should try to reset them to defaults to fix the issue.
Skin settings --> Configure shortcuts --> Restore shortcuts
If you do not want to reset them all you might want to try to just reassign them in the shortcuts editor.
(2015-12-01, 21:07)marcelveldt Wrote: [ -> ]
perfection thank you.
