Hi there peeps,
I have googled and searched the web and forums to find an answer, but i cannot seem to find any guide on how to create a DialogSubtitles.xml... In my case i just want to modify a certain subtitle script, for the Droid skin:
http://forum.kodi.tv/showthread.php?tid=219888 which will most likely never come out of beta stage.
I want to make it work with the existing button in the osd and make it usable, and if i rename the script to DialogSubtitles.xml it does pop up but does not work with the subtitles services installed... It gives an error with every subtitle service. It is also missing
(or i have missed it) a manual search link...
Can anyone (if they find the time and patience to do so) explain how to make it work? What do i need to modify to make it work? I would have just PM´d xhaggi for help but that is a deadly sin on this forum!
It is a shame that the Droid skin is being maintained, because it is on of the best skins for lightweight android devices...
Hope someone can help me!
Cheers,
Watts
(2015-11-30, 16:13)Watts Wrote: [ -> ]In my case i just want to modify a certain subtitle script
has the script been updated to the current kodi subtitle system?
if not, you'll have to start by fixing the python code of the script.
as for DialogSubtitles.xml, you could copy the one included in Confluence to the droid skin and take it from there.
the required controls in the dialog are explained here:
http://kodi.wiki/view/List_of_Built_In_C...titles.xml
edit:
and modify the subtitles button in the video osd to use:
<onclick>ActivateWindow(SubtitleSearch)</onclick>
(2015-11-30, 17:11)ronie Wrote: [ -> ] (2015-11-30, 16:13)Watts Wrote: [ -> ]In my case i just want to modify a certain subtitle script
the required controls in the dialog are explained here:http://kodi.wiki/view/List_of_Built_In_C...titles.xml
edit:
Hi there,
Thank you very much for pointing me into the right direction, i will try and get it all to work with the tips you gave me!
And i will also update the thread with my progress...
Cheers,
Watts.
EDIT
Got the SubtitlesDialog.xml to work and the button is working... But the subtitles services are giving errors (all of them).
This is the xml:
<?xml version="1.0" encoding="utf-8"?>
<window>
<allowoverlay>no</allowoverlay>
<include>PopUpEffect</include>
<onunload>ClearProperty(SubSettings,Home)</onunload>
<controls>
<control type="group" id="250">
<control type="group">
<posx>320</posx>
<posy>180</posy>
<animation type="Conditional" condition="!IsEmpty(Window(Home).Property(SubSettings)) | Control.hasFocus(150)">
<effect type="slide" start="0" end="240" easing="out" tween="cubic" time="200" />
</animation>
<control type="image">
<posx>-21</posx>
<posy>-21</posy>
<width>1322</width>
<height>762</height>
<texture border="4">dialogs/toast_back_blue.png</texture>
<bordertexture border="21">thumbs/thumb_shadow.png</bordertexture>
<bordersize>21</bordersize>
</control>
<control type="label" id="2">
<description>Heading</description>
<posx>0</posx>
<posy>0</posy>
<height>72</height>
<label>KODI SUBTITLES</label>
<width>840</width>
<textcolor>Blue2</textcolor>
<textoffsetx>30</textoffsetx>
</control>
<control type="image" id="110">
<description>Service Logo</description>
<posx>860</posx>
<posy>5</posy>
<width>400</width>
<height>62</height>
<aspectratio aligny="bottom" align="right">keep</aspectratio>
</control>
<posx>2</posx>
<posy>72</posy>
<width>1280</width>
<height>2</height>
<texture>common/blue2.png</texture>
</control>
<control type="label" id="100">
<description>textarea</description>
<posx>0</posx>
<posy>72</posy>
<width>1280</width>
<height>72</height>
<font>Small</font>
<textcolor>grey</textcolor>
</control>
<control type="list" id="120">
<posx>0</posx>
<posy>144</posy>
<width>1280</width>
<height>504</height>
<onleft>150</onleft>
<onright>121</onright>
<onup>120</onup>
<ondown>120</ondown>
<viewtype label="535">list</viewtype>
<pagecontrol>121</pagecontrol>
<scrolltime tween="quadratic" easing="out">200</scrolltime>
<itemlayout width="" height="72">
<width>1280</width>
<height>72</height>
<include>toast_back</include>
</control>
<posx>15</posx>
<posy>15</posy>
<width>62</width>
<height>42</height>
<aspectratio>keep</aspectratio>
<texture>$INFO[ListItem.Thumb,script.xbmc.subtitles/,/flag.png]</texture>
</control>
<posx>97</posx>
<posy>26</posy>
<width>68</width>
<height>22</height>
<texture>script.xbmc.subtitles/sync.png</texture>
<visible>ListItem.property(sync)</visible>
<colordiffuse>White2</colordiffuse>
</control>
<control type="label">
<posx>155</posx>
<width>893</width>
<height>72</height>
<font>Small</font>
<label>$INFO[ListItem.Label2]</label>
<textcolor>White2</textcolor>
<visible>ListItem.property(sync) + ListItem.property(hearing_imp)</visible>
</control>
<posx>97</posx>
<width>941</width>
<height>72</height>
<font>Small</font>
<textoffsetx>5</textoffsetx>
<visible>!ListItem.property(sync) + ListItem.property(hearing_imp)</visible>
</control>
<posx>97</posx>
<width>1008</width>
<height>72</height>
<font>Small</font>
<visible>!ListItem.property(sync) + !ListItem.property(hearing_imp)</visible>
</control>
<posx>180</posx>
<width>925</width>
<height>72</height>
<font>Small</font>
<visible>ListItem.property(sync) + !ListItem.property(hearing_imp)</visible>
</control>
<posx>1048</posx>
<posy>6</posy>
<width>60</width>
<height>60</height>
<texture>script.xbmc.subtitles/cc.png</texture>
<visible>ListItem.property(hearing_imp)</visible>
</control>
<posx>1115</posx>
<posy>19</posy>
<width>160</width>
<height>34</height>
<texture>$INFO[ListItem.ActualIcon,flags/stars/,.png]</texture>
</control>
</itemlayout>
<focusedlayout height="72">
<width>1280</width>
<height>72</height>
</control>
<width>1280</width>
<height>72</height>
<texture>dialogs/listitem_focus.png</texture>
<visible>Control.HasFocus(120)</visible>
</control>
<posx>15</posx>
<posy>15</posy>
<width>62</width>
<height>42</height>
</control>
<posx>97</posx>
<posy>26</posy>
<width>68</width>
<height>22</height>
</control>
<posx>155</posx>
<width>893</width>
<height>72</height>
<font>Small</font>
</control>
<posx>97</posx>
<width>941</width>
<height>72</height>
<font>Small</font>
</control>
<posx>97</posx>
<width>1008</width>
<height>72</height>
<font>Small</font>
</control>
<posx>180</posx>
<width>925</width>
<height>72</height>
<font>Small</font>
</control>
<posx>1048</posx>
<posy>6</posy>
<width>60</width>
<height>60</height>
</control>
<posx>1115</posx>
<posy>19</posy>
<width>160</width>
<height>34</height>
</control>
</focusedlayout>
</control>
<control type="group" id="111">
<control type="button">
<posx>90</posx>
<posy>648</posy>
<width>1190</width>
<height>72</height>
<font>Small</font>
<label>$LOCALIZE[SCRIPT655]</label>
<disabledcolor>White2</disabledcolor>
<enable>no</enable>
</control>
</control>
<posx>0</posx>
<posy>648</posy>
<width>72</width>
<height>72</height>
<control type="button" id="11115">
<posx>0</posx>
<posy>0</posy>
<width>90</width>
<height>72</height>
<onclick>SetProperty(SubSettings,True,Home)</onclick>
<onclick>SetFocus(150)</onclick>
<onleft>120</onleft>
<onup>120</onup>
</control>
<posx>21</posx>
<posy>12</posy>
<width>48</width>
<height>48</height>
<texture>icons/settings_nf.png</texture>
</control>
</control>
<control type="spincontrol" id="121">
<description>Next page button</description>
<posx>1136</posx>
<posy>648</posy>
<width>72</width>
<height>72</height>
<font>Small</font>
<align>right</align>
<subtype>page</subtype>
<onleft>11115</onleft>
<onright>11115</onright>
<onup>120</onup>
<showonepage>false</showonepage>
<visible>Control.IsVisible(120)</visible>
</control>
</control>
<posx>-400</posx>
<posy>180</posy>
<animation type="Conditional" reversible="false" condition="!IsEmpty(Window(Home).Property(SubSettings)) | Control.HasFocus(150)">
<effect type="slide" start="0" end="480" easing="out" tween="cubic" time="200" />
<effect type="fade" start="0" end="100" time="200" />
</animation>
<animation type="Conditional" reversible="false" condition="IsEmpty(Window(Home).Property(SubSettings)) + !Control.HasFocus(150)">
<effect type="fade" start="100" end="0" time="200" />
<effect type="slide" end="0" start="480" easing="out" tween="cubic" time="200" />
</animation>
<posx>-21</posx>
<posy>-21</posy>
<width>522</width>
</control>
<description>XBMC Subtitles label</description>
<posx>0</posx>
<posy>0</posy>
<width>480</width>
<height>72</height>
<label>$LOCALIZE[SCRIPT760]</label>
<font>Small_Caps</font>
</control>
<control type="list" id="150">
<posx>0</posx>
<posy>72</posy>
<width>480</width>
<onleft>11116</onleft>
<onright>11116</onright>
<onup>150</onup>
<ondown>11116</ondown>
<scrolltime>200</scrolltime>
<orientation>vertical</orientation>
<hitrect x="0" y="0" w="480" h="1080" />
<itemlayout width="480" height="72">
<width>480</width>
<height>72</height>
</control>
<width>480</width>
<height>72</height>
<font>Small</font>
<label>$INFO[ListItem.Label]</label>
<scroll>true</scroll>
<visible>!ListItem.property(man)</visible>
</control>
<width>480</width>
<height>72</height>
<font>Small</font>
<visible>ListItem.property(man)</visible>
</control>
</itemlayout>
<focusedlayout width="480" height="72">
<!-- Gives error in log: WARNING: Trying to add unsupported control type 1 -->
<width>480</width>
<height>72</height>
<include>HiddenButton</include>
<onunfocus>ClearProperty(SubSettings,Home)</onunfocus>
</control>
<width>480</width>
<height>72</height>
</control>
<width>480</width>
<height>72</height>
<visible>Control.HasFocus(150)</visible>
</control>
<width>480</width>
<height>72</height>
<font>Small</font>
</control>
<width>480</width>
<height>72</height>
<font>Small</font>
</control>
</focusedlayout>
</control>
<control type="button" id="11116">
<posx>0</posx>
<posy>648</posy>
<width>480</width>
<height>72</height>
<onclick>ClearProperty(SubSettings,Home)</onclick>
<onclick>SetFocus(120)</onclick>
<onright>150</onright>
<ondown>150</ondown>
<onup>150</onup>
<label>222</label>
</control>
<posx>2</posx>
<posy>72</posy>
<width>480</width>
<height>2</height>
</control>
</control>
</control>
</controls>
</window>
What am i missing here?
