2009-01-21, 13:45
2009-02-11, 22:35
um, where can I download this skin from. Is it available alone, I don't want to update my XBMC build by getting a new SVN.
Edit, I think I found it, is the one here the latest build?
http://blackmarket.ictcsc.net/files/skins/
2009-10-27, 15:51
It looks like Vision has a few broken parts,
dialogs for: adding sources, custom background and a few more I'm sure.
I see that Jezz_X is familiar with a similar problem here:
http://forum.xbmc.org/showthread.php?tid=56644
http://xbmc.org/jezz_x/2009/08/23/updati...-classics/
Jezz_X, if it's not to much trouble....
If you are too busy, point me in the right direction and I'll give it a shot.
I've been slowly modifying Vision to look like I want it to, with many more mods to come,
but this one has me confused as it's a wee bit beyond my capability, or I missed something in the wiki http://www.xbmc.org/wiki/?title=XBMC_Skinning_Tutorials
2009-10-27, 22:21
I can take a look at it but might not be able to do anything for a few weeks been a bit busy with other stuff at the moment
2009-10-28, 05:06
Thanks, I know that you are busy with many projects and most likely home life as well, when you get to it you get to it.
Post your findings and possibly point me in the right direction and I'll try to fix it.
As long as some time in the future it works like it used to I'll be very happy.
Meanwhile I'll continue with my mods.
I forgot to add in my first post:
XBMC and Vision are both current Revisions, and Vision broke somewhere between Atlantis and Babylon
2009-10-28, 07:02
What you need to do for starters is find all the old Listcontrol and Thumbnailpanel controls in the skin and replace them with the new List and Panel controls
2009-12-04, 13:16
Thanks for the help Jezz,
I think I'm going back to Atlantis, I had less problems with it in general and with xbmc for xbox development slowing down...
I think I'll just have to wait till I get around to building a htpc, maybe someone will have fixed it by then.
2011-03-17, 04:33
WeirdH Wrote:This is looking incredible!!
However, I think most feedback will start coming your way once people get a hands-on feel for it. Right now, I'm just pretty much in awe of the graphics, so that won't give you any idea of what to change/improve.
Other feedback (ie. on things that look good, but unfortunately aren't user-friendly, or things that just look out of place) would have to be based on what I encounter while using it...
And that's just a lot of fancy talk for saying: gimme!!!
Looking forward to this.
I also think so.
__________________
Watch Mars Needs Moms Online For Free
2011-03-17, 18:24
You didn't noticed this thread is dead?
h.udo
h.udo
