2007-04-17, 23:23
2007-04-18, 01:43
pleeeaaasee go on with titanium!!!
2007-04-20, 09:24
titanum will be more unique. no question about it.
p.s.: the new home-slider "vertikal-anim" is damn cool.
could something like that be done for the submenu, too?
2007-04-20, 22:06
I noticed that long notification text overflows from the notification window.
You should probably clip it or turn them into fade labels.
2007-04-20, 23:20
NineT9mustang Wrote:Thanks dxg836 Glad to see people still like it... I thought ppl would only like it for a week then go back to which skin they came from heheis that so...you an't even finished Vision...you forgot this is just the beta. I guess you love skin
I personally want to start Titanium too... but with PM3, I can get that done a lot sooner... (Since Im just edited images to fit... not creating new ones like Titanium)
no go with pm3, since you can finish it faster.
We will bang out PM3 & Vision while you are kindly working on Titanum
2007-04-23, 18:58
hey how do you play a DvD when loaded!?
I can't seem to play a movie dvd:/
the same applies to the Project Gotham 3
I can only load the DvD on MC360
Do I have to turn on: auto play Dvd!?
2007-04-24, 00:09
make a dvddrive share in your sections
2007-04-25, 10:13
I love Vision skin. It looks so slick.
However, playing DVD without the menu is a big minus that I have to switch to other skins.
Bandgap
Bandgap
2007-04-25, 14:35
bandgap112 Wrote:I love Vision skin. It looks so slick.if you mean the dvd menu button in the OSD I just added it
Bandgap
2007-04-25, 16:47
it does matter now
I just have to press the white button on the Play DvD under the Video Section
But on the main menu. When you don't load anything, the orb is black. When a user inserts a cd, the blackorb should show an image or sign. So when the user clicks on the black orb, it loads the DvD.
Also when a user is listening to an album, the album image suppose to show on the black orb, instead of the cd image:/
I saw someone playing a music and the image did show..how da hell did he do that:/
2007-04-27, 21:39
Thanks for adding the OSD DVD menu button. It works great. Now I'm back to Vision skin.
Is it possible to add feature to show the resolution (zoom, stretch 14x9, 16x9, 720p, 1080i) on the screen when we hit the zoom button? I think the info is useful, and it exists on other skins.
Thanks,
bandgap
Thanks,
bandgap
2007-04-28, 02:32
Well since this is my current primary skin I should help with the feedback...
This is all tested in NTSC
1. Notification Dialog labels not clipping right in NTSC.. (dialogkaitoast.xml)
2. Video Info dialog (black button) only shows the first 2 lines not 3 lines (bug is an extra <visible>no</visible> in VideoFullScreen.xml)
3. In Home.xml I think you should use
<onclick>XBMC.ActivateWindow(1,Apps)</onclick>
instead of
<onclick>XBMC.ActivateWindow(1,Programs)</onclick>
Since that is more common.
4. Consider the new Favorites dialog that JM added a few days ago.
instead of
2007-04-28, 05:19
Asteron Wrote:Well since this is my current primary skin I should help with the feedback...
instead of
1) Fixed Can't beleive no one posted it before
2) Also done
3) Probably not because its the way mc360 has always worked and since is was first and more popular most people probably have it set like that allready
4) Yeah I'm getting too it soon
2007-04-28, 13:27
2007-04-28, 22:07
Jezz_X Wrote:1) Fixed Can't beleive no one posted it before
2) Also done
Thanks! ...Clicks SVN Update...
